Coolant Leak
Old Sep 18, 2007 | 06:33 AM
hassan21's Avatar
Default this sh*t is weird
so i replaced the raditor
it doesnt overheat ne more
im pretty glad with that.
but this morning when i woke up i noticed a puddle of raditor fluid under my car.
what the hell could be leaking raditor fluid now?
Old Sep 18, 2007 | 06:35 AM
290allen's Avatar
Default this **** is weird (hassan21)
just pop your hood to find out, probably a small hose or something. Shouldnt be too hard to find.
Old Sep 18, 2007 | 06:36 AM
Pooper's Avatar
Default Re: this **** is weird (hassan21)
i would start the car and just go over everything you touched and everything you didn't touch. it can only be coming from so many places. i would check all of them.
hassan21's Avatar
yeah im going to do that today.
hopefully its a hose.
do you think it could be ne thing else?
Old Sep 18, 2007 | 06:59 AM
~sp33~'s Avatar
EFB055
More then likely it will be a hose, unless your waterpump has a real bad case of ghastritus.
Old Sep 18, 2007 | 08:23 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
check that stupid thing that brings coolant to the TB if your motor has it. Thats leaked on me a bunch of times.
Old Sep 18, 2007 | 08:28 AM
jay di em02's Avatar
probably a hose
Old Sep 18, 2007 | 12:39 PM
Scotland:EF3's Avatar
check the heater hose they usally crack or break at the clamp
Old Sep 18, 2007 | 04:10 PM
ef9alldatime's Avatar
Default Re: (ProJect:EF3)
check the butterfly thingy on the side to the left on the radiator
Old Sep 18, 2007 | 06:01 PM
DWeigs's Avatar
I would check the hoses and then look at the water pump.... Mine went one day without even giving any notice or anything...
Old Sep 18, 2007 | 07:25 PM
peanut butter's Avatar
Default Re: (DWeigs)
Also check the drain plug on the radiator
Old Sep 18, 2007 | 08:34 PM
hassan21's Avatar
i took it for a cooling system pressure test.
it came out fine.
no leaks.
i know that my resever tank that is attached to my car has a hole in it.
also it overfills when i have no water in it.
is it supposed to be doing that?
Old Sep 18, 2007 | 09:18 PM
jpciii's Avatar
how can the tank overfill when it is empty?
Old Sep 19, 2007 | 12:18 PM
hassan21's Avatar
well itll over flow when i put water in the raditor.
idk its a weird thing with my cooling system
Old Sep 19, 2007 | 07:40 PM
Default Re: (hassan21)
check the radiator cap
Old Sep 20, 2007 | 12:20 PM
hassan21's Avatar
the radiator cap is fine.
i just bought it like a week ago
Old Sep 21, 2007 | 02:24 AM
Rd91SiB18ls's Avatar
Start the car with the radiator cap off, when cold and look for bubbles.
If it has a blown head gasket it will fill the overflow.
If you see bubbles it has a blown gasket.
Old Sep 21, 2007 | 02:29 AM
hassan21's Avatar
but if it has a blown head gasket wouldnt it have coolent in the oil or even in the radiatior?
Old Sep 21, 2007 | 02:40 AM
Not allways might be a small leak, could be just blowing into the water galley
Old Sep 21, 2007 | 02:43 AM
hassan21's Avatar
hmmmm but when i took off the valve cover and chaged the valve cover gasket i didnt see cream or ne thing. also wouldnt i know it from the pressure test? i mean i left the tester on there for like 2 mins and nothing happened.
how hard is it to replace?
Old Sep 21, 2007 | 03:09 AM
not easy for a beginer runs about $500 at a shop.
how bad did you overheat it.
Jibin
Apr 24, 2010 07:42 PM
jdmboy94
Jan 21, 2009 09:48 PM
95hatchcivic
15
Mar 24, 2007 01:01 PM
yOnKiNaToR
Sep 20, 2006 10:46 AM
EARLdaSQUIRREL
Dec 1, 2005 04:30 PM
