Buying a 95 GSR
Old Sep 18, 2007 | 05:32 AM
2002silverex's Avatar
Default Buying a 95 GSR
Im supposed to be buying a 95 integra with a 2001 gsx engine and tranny in it.
THe engine is basiclaly stock, with a few bolt ons.
Anyways, the guy told me that he has to add oil to it every once in a while... but it doesnt smoke, or leak oil.. so it must be burning it?
he said the gsr's are notorious for this.... can anyone shed some light on that?
the engine supposedly only has 30k on it?
Old Sep 18, 2007 | 06:25 AM
St Jimmy's Avatar
* B A N N E D *
Default Re: Buying a 95 GSR (2002silverex)
He is lying to you, smoking and using that much oil is usually caused by excessive wear or just lots and lots of normal wear, which with 30k miles thats nothings for a honda and it certainly shouldn't be smoking. He is lying to you.
Old Sep 18, 2007 | 06:51 AM
No...its NOT smoking...just using a little. He said he checks it every couple of weeks and topsit off. Not smoking. Not Leaking...
Old Sep 18, 2007 | 06:59 AM
nate_2k5's Avatar
Default Re: (2002silverex)
gsx engine eh...
well it must be burning or leaking somewhere, matter neither be created or destroyed without nuclear technology.
Old Sep 18, 2007 | 07:03 AM
gsr engine...sorry typo
Old Sep 18, 2007 | 09:20 AM
hbcrazy88's Avatar
check the gsr cam seal. there notoruis for leaking. do you have oil running down from what looks to be the head down the block/ tranny?
Old Sep 18, 2007 | 09:32 AM
No, i dont have the car yet. I am buying the car, avent seen it yet. The guy im buying it from said its not leaking, or smoking, but does burn a LITTLE oil
Old Sep 18, 2007 | 09:38 AM
goheel's Avatar
the engine shouldn't consume any oil if it only has 30k miles. Mine has 100k and it still doesn't consume oil. This is shady, stay away. IMO, don't buy swapped cars, you don't know the true history of the car, and most of the time, the owners aren't really honest.
Old Sep 18, 2007 | 09:45 AM
SUPPOSEDLY>>> heres the story:
Was origonally a 95 gsr. Got in a front end colission... swapped in a 95 gsr engine with 01 gsr tranny... engine has 50k tranny has 30k.
It now has CAI,H,E...type-r pistons and rings...lightweight flywheel.....stage 1 clutch.... msd plugs,wires, and ignition...
ANd he said he checks the oil 1nce ever couple of weeks and if its low at all, he adds some to it.. meaning it must be burning a little bit.
Old Sep 18, 2007 | 11:21 AM
TehGhett0P1mp's Avatar
Do a leakdown and compression test and that will tell you if the engine is ok or not. If he only has to top it off every few weeks(Then again how much is "top off"?) then it should be ok assuming the leakdown and compression come back alright.
Old Sep 18, 2007 | 11:23 AM
St Jimmy's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2002silverex &raquo;</TD></TR><TR><TD CLASS="quote">SUPPOSEDLY&gt;&gt;&gt; heres the story:
ANd he said he checks the oil 1nce ever couple of weeks and if its low at all, he adds some to it.. meaning it must be burning a little bit.</TD></TR></TABLE>
If it has new pistons and rings that means it was at the least mildly rebuilt. It shouldn't use ANY oil unless he is throttle happy or lying to you, both wouldn't make me want to buy the car. Why would a motor with new pistons and rings and only 50k burn oil? My motor has 175k and the only time I burn oil is when I get close to redline.
Old Sep 18, 2007 | 01:30 PM
goheel's Avatar
Default Re: (St Jimmy)
like i said, very shady, buy it at your own risk. You've been warned, don't come back to this board later and complain why your car breaks down later on.
Old Sep 18, 2007 | 05:28 PM
A's 94 GSR's Avatar
BG-33P
Default Re: (hbcrazy88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hbcrazy88 &raquo;</TD></TR><TR><TD CLASS="quote">check the gsr cam seal. there notoruis for leaking.?</TD></TR></TABLE>
mine is leaking all over my tranny
j4s0n1337
Aug 17, 2011 12:07 AM
viet_sensationz
Jun 28, 2007 02:05 AM
GSRoadRage
Sep 30, 2004 08:06 PM
thericker72
Jul 26, 2004 01:15 PM
toooslow
Jun 8, 2003 07:09 PM
