Cylinder wall chip. GSR block.
I'm in need of a GSR block.
I found one but it has a small chip on the bottom of cylinder 1. It's a pretty deep chip about a centimeter or two above the very bottom. I want to know if this will affect compression in any way. Does the piston ring go all the way to the bottom of the cylinder?
Need your help. Thanks.
Ok. I didn't think of that.
The block is gonna get a hone for a new set of P30's but not a bore. Thanks. Gonna double check on that.
It appears there's more damage in the cylinder. Machine shop said if I want to keep the standard bore, they can order a sleeve for that one cylinder (other three will be fine with a hone) and re-sleeve it for me. They gave me a very good price compared to the Benson and Darton sleeves.
Has anyone ever done this?
ask them if it was more than say a .50 bore might get by with just buying like some .50 over type r pistons or somethin have some fun and be creative while you got it apart. but it very well may just be that fucked up i dunno hadn't seen it first hand.
if the machine shop is gonna have to shave 1mm or more off the cylinder wall than ur gonna need new sleeves. if u cant afford to do it than maybe just either sell it or hold on to it till u have enough money to resleeve it. do not attempt to build it like that with stock sleeves.
Rosko
12
Mar 17, 2007 04:09 PM
