wheel bearing replacement?
im rebuilding my whole suspension setup, new bushings, ball joints...
my question is do you guys recommend oem honda wheel bearings or will i be ok using "local auto parts store" bearings?
honda oem uses NTN bearings. you can get the same bearing from any bearing supplier given the right mfg part number or dimensions. its on your old bearing.
there are equally or better quality bearings from other bearing manufacturers like ***. then there are others... stay away from the others.
btw i think if you get a new bearing from the dealer, itll have a different colored seal on one side. the grey side goes on the INside.
Modified by Tyson at 2:58 AM 9/19/2007
blan
Honda Civic (2006 - 2015)
Jul 2, 2011 04:27 PM
jisu009
22
May 21, 2004 11:42 AM
