D16A6 Head gasket options
Old Jun 17, 2002 | 10:31 AM
Todd00's Avatar
I said I don't want a title!
Default D16A6 Head gasket options
Is the rumor true that you can use a head gasket off of a 92-95 Civic Si and get a few points in compression on the D16A6 motor?
Also, there has been an updated part# to the D16a6 gasket. Anyone know if this is good for a few compression points? I know they changed it to a metal type of gasket.
Old Jun 17, 2002 | 12:39 PM
Urban Business
Guest
Posts: n/a
Default Re: D16A6 Head gasket options (Todd00)
i believe any d series head gasket will work. use copper gaskets, crank em down once and never again. to gain compression use a thinner gasket that whats currently on there
Old Jun 17, 2002 | 12:46 PM
d357r0y's Avatar
you could use the y8 if you want to go even thinner
Old Jun 17, 2002 | 06:16 PM
seekerONE's Avatar
88-95 non-vtec d series used a composite gasket...later found to be prone to oil leaks. honda issued service bulletin concerning this saying updated part available...yep you guessed it 92-95 vtec metal gasket. as said before you can use 92-95 gasket(Z6) or 96-2000 gasket(Y8)...y8 is slighter thinner for very slightly more compression and is less $$$ to boot.
Old Mar 24, 2009 | 05:36 PM
Brujo13's Avatar
so witch one would be safer for a daily driven 88 crx si, with reliability first and foremost?
1gEF-8
Jun 30, 2005 06:19 AM
acongdon
Oct 9, 2003 12:52 PM
DarkSubRosa
Mar 19, 2003 03:25 PM
