Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Gas Prices....SI question.
Old Sep 17, 2007 | 06:54 PM
iamtwan's Avatar
Default Gas Prices....SI question.
I was just wanted to get some info (for future reference) how much does it normally take to fill up your SI's and at what avg price of gas? thanks
Old Sep 17, 2007 | 09:40 PM
blondecivic's Avatar
Default Re: Gas Prices....SI question. (iamtwan)
I live in AZ and gas here is about 2.95 a gallon. It costs me about 30-35 buck when I fill up... Try http://www.gasbuddy.com and you can check gas prices nation wide or in your home town and see where its the cheapest
Old Sep 17, 2007 | 11:05 PM
gus738's Avatar
Default Re: Gas Prices....SI question. (blondecivic)
2.95 for preimuim gas? assuming ur putting preimum as its only a si
Old Sep 18, 2007 | 12:47 AM
MisterNiceGuy's Avatar
Default Re: Gas Prices....SI question. (gus738)
Down here Premium prices vary from $3.05-3.15, I usually fill entire tank sometimes from 2 sticks (orange light) for $35-37 bucks.
Old Sep 18, 2007 | 01:58 AM
clemsonhatch's Avatar
Default Re: Gas Prices....SI question. (MisterNiceGuy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gus738 &raquo;</TD></TR><TR><TD CLASS="quote">2.95 for preimuim gas? assuming ur putting preimum as its only a si </TD></TR></TABLE>
I filled up yesterday with 93 for $2.71 per gallon.
Old Sep 18, 2007 | 05:54 AM
iamtwan's Avatar
Default Re: Gas Prices....SI question. (clemsonhatch)
thanks for all the info. guessing its most likely gonna cost around 35-40 to fill up down here in diego depending on the price of premium...
Old Sep 18, 2007 | 06:02 AM
Type X's Avatar
I go to NJ to fill up
and its usually about 33-34 dollars.
Old Sep 20, 2007 | 06:58 PM
gus738's Avatar
Default Re: Gas Prices....SI question. (Type X)
last time i filed my ex auto was 32.15 i belive thats when it clicked..... iduuno im on 2 stick bars orange light came up so ill be putting gas once i leave the house.
(was on my way home) i put gas from cheveron or shell or 76 ..... nothing else and only preimum and yes im aware my ex isnt highly powerd therefore not requiring priemum dont care .....
Old Sep 20, 2007 | 07:41 PM
mInI m3 Hondeezy's Avatar
Right now its at 2.89 over here and i pumped 20 dollars and got a little over 6 gallons.
Old Sep 20, 2007 | 09:15 PM
Gas prices suck!
Old Sep 20, 2007 | 09:36 PM
bbRedSi's Avatar
ouch to some! I put 20 bucks in today and got almost 7.5 gallons. 2.69 for 93 octane! most other places around here are about 2.80 for premium tho
Old Sep 20, 2007 | 10:20 PM
gus738's Avatar
Default Re: Gas Prices....SI question. (bbRedSi)
how do you know how many gal its taking
Old Sep 21, 2007 | 04:14 AM
Michael Bolton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gus738 &raquo;</TD></TR><TR><TD CLASS="quote">how do you know how many gal its taking </TD></TR></TABLE>
Old Sep 21, 2007 | 07:31 AM
Huh wtf?says it at the pump when your'e pumping it.
Old Sep 21, 2007 | 11:15 AM
p nut's Avatar
Looks like the weekend started a bit early in CA.
To the original question: Still don't understand how this applies to the Si or even a Civic in general. What does it matter how much other people are paying for gas? Look at what the gas costs at your local gas station. Then look up what the gas tank capacity is in the Si (or any Civic), which is about 13gal. Then do some simple math (which if you can't figure that out, you shouldn't be behind a wheel).
Miles per gallon should be your main point of research. And that can be found by using the search function.
Old Sep 21, 2007 | 11:30 AM
iamtwan's Avatar
Default Re: Gas Prices....SI question. (p nut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p nut &raquo;</TD></TR><TR><TD CLASS="quote">
Miles per gallon should be your main point of research. And that can be found by using the search function.</TD></TR></TABLE>
fair enough....
Old Sep 21, 2007 | 11:38 AM
Hellzcivic's Avatar
Here in CA (Silicon Valley) Premuim (91 Octane) is $3.15 to $3.25. If I filled with JUST premium it would run me around $33 to $35 bucks.
However, because of the supercharger, I like running some 100 Octane with the 91 Octane. 100 Octane is $5.60 a gal. I run 4 gallons of 100 octane with 6 to 7 gallons of Premuim. The mixed cost per gallon runs me around $4.11 or $43 bucks a tank.
xkrntamax
14
Oct 1, 2008 10:42 AM
urafag
Jun 30, 2006 05:07 AM
Baron55
Oct 10, 2005 01:09 PM
adaml2nv
Jun 6, 2004 04:50 AM
CDN Yellow ITR
Nov 13, 2003 06:19 AM
