Mini Me Experts!!!
Old Jun 17, 2002 | 10:06 AM
xpurespeedx's Avatar
Default Mini Me Experts!!!
I just finished putting a y8 head on a sohc zc block(d16a6) and it runs like crap. I have a B&M fuel press. regualtor, a feilds vtec controller. Just wanted to know what everyone has there timing set at, and there fuel pressure. Also I have a AEM adjustable cam gear, do you leave it at 0 degrees or should I adjust it any. My timing is at 14 degrees now; but I had it set at 16 degrees and it was pinging really bad, it still pings a little now just need some help trying to tune everything in. I am also running the stock ecu. Any help would be great. Thanks
[Modified by xpurespeedx, 7:17 PM 6/17/2002]
Old Jun 17, 2002 | 10:19 AM
Speed PHreak's Avatar
Default Re: Mini Me Experts!!! (xpurespeedx)
got octane? 93 is best.
Old Jun 17, 2002 | 10:20 AM
Default Re: Mini Me Experts!!! (Speed PHreak)
Yes I am running 93 octane, thats why im confused, it shouldnt be pinging.
Old Jun 17, 2002 | 10:21 AM
mafioso102's Avatar
New User
yup. with that high of compression (from the mini me) you can only run high octane gas
Old Jun 17, 2002 | 10:22 AM
My vtec controller will let you adjust the fuel in 1% increments, should i set it at zero and start from there also what do you have your vtec set at to kick in.
Old Jun 17, 2002 | 10:36 AM
XPystchrisX's Avatar
find the timing for a stock d16y8 and start a few degrees behind that. so if stock timing was 15 degrees btdc then go 10 degrees btdc and work foreward. i would really recommend doing this kind of thing on a dyno with a wideband o2 sensor. that way you can tell exactly what is going on and when. you run very little chance of destroying everything, there's still that chance tho... you never know.
btw how was your install? was it complicated? how much did parts cost you total? i'm not sure if i want to do a head swap or a camshaft and motor work.
Old Jun 17, 2002 | 10:43 AM
Default Re: Mini Me Experts!!! (XPystchrisX)
The install wasnt that bad its just trying to tune the thing that is hard. I got all the parts for pretty cheap because i have a friend that works at a honda dealership. They ended up costing me about 350 for everything and i also rebuilt my head with ne vavle seals and cleaned it all up. He is a mechanic there and has a crx with a d16a6 block and a y8 head with a act clutch, zex cam(big one) and i/h/e and he is running 13.4's no joke Ive seen it in person its awesome.
[Modified by xpurespeedx, 7:44 PM 6/17/2002]
Rishiras
Mar 28, 2006 08:26 PM
Azn Kenny
Jan 31, 2006 06:11 PM
xpurespeedx
11
Jul 15, 2002 06:12 AM
BTR ALL MOTOR
Jan 8, 2002 03:23 PM
