FIT Valve (Fast Idle Thermo Valve)
Old Sep 17, 2007 | 05:07 PM
conan385's Avatar
Default FIT Valve (Fast Idle Thermo Valve)
Question for someone who knows about the FIT. The Chilton book states that if you take the top cap off of the valve when the car is cold, you should feel air with your finger. Once warm, you should not. My question is, is this true if you push gently on the copper colored plunger like you are unseating the valve or should there be air there without having to push it down. The part is about $90 so I don't want to buy it unless I have to. Also, if I don't replace it, what is the deal since it doesn't seem to be hurting anything now.
Old Sep 18, 2007 | 05:13 AM
GhostAccord's Avatar
Default Re: FIT Valve (conan385)
Yes, this is true. If you push the plunger it should stop the flow of air. Acting as thought the valve is up to operating temperature.
Why did you investigate the FIT valve if you were not experiencing any problems?
If your not having any idle issues then you should be good to go without replacing the valve. I ran my 96 with the FIT valve blocked off for the past two years. The car idled fine even in -30c weather.
Old Sep 18, 2007 | 06:02 PM
conan385's Avatar
Default Re: FIT Valve (GhostAccord)
Just doing some PM type stuff and noticed that there is no air felt when starting up cold. I have a rough idle sometimes so I am just probably going to pull the FIT and the IAC and clean them real well. Nothing is wrong, which is why I don't really want to buy the part.
Old Sep 18, 2007 | 06:35 PM
accord99power's Avatar
BG Throttle body cleaner is your friend
Old Sep 18, 2007 | 07:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by conan385 &raquo;</TD></TR><TR><TD CLASS="quote">Just doing some PM type stuff and noticed that there is no air felt when starting up cold. I have a rough idle sometimes so I am just probably going to pull the FIT and the IAC and clean them real well. Nothing is wrong, which is why I don't really want to buy the part.</TD></TR></TABLE>
It's good to keep up on the PM
Old Sep 18, 2007 | 08:33 PM
Grandhustleman86's Avatar
no hijackin here, but im currently in iraq so im not drivin my ol' girl, but even with doin all the cleaning, parts after almost 15yrs. just fail....so I just coughed out the dough for the FITV + IACV and am calling it quits....it would run good for a couple of days but thats about it....Genuine Honda OEM FTMFW
wallermh
Transmission & Drivetrain
Oct 17, 2014 03:57 PM
2008Fit
Honda Fit
Jan 3, 2013 01:19 PM
marcaobr
Nov 16, 2005 08:09 PM
Ri5e
Jun 28, 2002 11:32 AM
