upgrading rotors?
Using different rotors will not make a significant difference in stopping power.
Two-piece rotors will last longer when subjected to heat from track use, but are expensive.
I've found that all better-quality one-piece rotors last pretty much the same amount of time and number of track miles. That's why I'm using the $25 Duralast rotors from Autozone, even on my heavily-tracked car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94rs-turbo »</TD></TR><TR><TD CLASS="quote">I am very supprised how much people like the vatozone rotors</TD></TR></TABLE>
im *surprised how many people dont track thier r's
gsr's might have been a better option
Why? Rotors are a wear item. Those that can drive their Hype R near the limit on the track will burn up a set of fronts in a weekend. No sense in paying for the Brembo name when a set of Autozone cheapies will do the same job, and go in the same trash bin.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Splat »</TD></TR><TR><TD CLASS="quote">
Why? Rotors are a wear item. Those that can drive their Hype R near the limit on the track will burn up a set of fronts in a weekend. No sense in paying for the Brembo name when a set of Autozone cheapies will do the same job, and go in the same trash bin.</TD></TR></TABLE>
TRUTH right thur.
TRUTH right thur.
Read it again...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Splat »</TD></TR><TR><TD CLASS="quote">Why? Rotors are a wear item. Those that can drive their Hype R near the limit on the track will burn up a set of fronts in a weekend. No sense in paying for the Brembo name when a set of Autozone cheapies will do the same job, and go in the same trash bin.</TD></TR></TABLE>
HEY!!! I OUOTED PAT !st!!!! XXXXX
It needed to be said once more...
Why, you...... I outta...........
quote it again.
quote it again.
thanks guys for the replies. well i just decided to have my stock rotors resurface. i just considered the slotted rotors becuase i thot they would last longer. well since my car is DD and not a track whre.. ill just use my stock rotors and some great pads :D how are the hawks street perf?
The Autozone rotors don't go in the trash. They go back to the customer service desk when they are cracked with and they give you another set for free. That's why I use the Autozone rotors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bradstard »</TD></TR><TR><TD CLASS="quote">
I thought the Harris boys had single-handedly ruined that warranty?
Truth - it used to be a year at least, now it's what, three months?
</TD></TR></TABLE>I thought the Harris boys had single-handedly ruined that warranty?
Truth - it used to be a year at least, now it's what, three months?</TD></TR></TABLE>
hahaha, that'd be a belter
According to the website, it's 2 years on the Legend Duralast rotors. I've never had a problem exchanging them. They look at them funny sometimes and ask what the hell happened. They usually say that you probably have a stuck caliper and should get that fixed
you're a bad man
</TD></TR></TABLE>you're a bad man
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bradstard »</TD></TR><TR><TD CLASS="quote"> They look at them funny sometimes and ask what the hell happened. They usually say that you probably have a stuck caliper and should get that fixed
LMFAO!! "They only get stuck at the end of the straights"
</TD></TR></TABLE>LMFAO!! "They only get stuck at the end of the straights"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Splat »</TD></TR><TR><TD CLASS="quote">Rotors are a wear item. Those that can drive their Hype R near the limit on the track will burn up a set of fronts in a weekend.</TD></TR></TABLE>
Use up a set of rotors in a weekend? Nonsense. I put 1,366 actual track miles (over 10K total miles) on my last set of Autozone rotors before I had to replace them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bradstard »</TD></TR><TR><TD CLASS="quote">The Autozone rotors don't go in the trash. They go back to the customer service desk when they are cracked with and they give you another set for free. That's why I use the Autozone rotors
for cheating, taking advantage of a warranty that was never intended to replace parts for track use. That is WRONG, and you know it. Shame on you!
