shift linkage not long enough
Old Sep 17, 2007 | 02:24 PM
slowcrx954's Avatar
Default shift linkage not long enough
i did a ls swap into a 1991 crx si and with and old b series linkake form ebay wont reach?is there a way i could have really put the motor in wrong?its on jack stands now could that be the problem?
Old Sep 17, 2007 | 02:33 PM
Crx Jimmy's Avatar
Default Re: shift linkage not long enough (slowcrx954)
how far is it off by like 1" or a lot?
Old Sep 17, 2007 | 05:34 PM
gibsanez's Avatar
Default Re: shift linkage not long enough (Crx Jimmy)
Is it stock linkage? If it is, you have to either cut and weld, or buy adjustable linkage.
Old Sep 17, 2007 | 05:58 PM
denraweb's Avatar
Default Re: shift linkage not long enough (gibsanez)
I have the same problem. I have a hasport shift linkage for a jdm b16 and it's about 1/2" too short. Just use a pice of metal to extend it, like get an old linkage and cut off a straight piece, then cut the shift linkage you have and place the cut piece from the old shift linkage in it's place to space it.
Old Sep 18, 2007 | 06:11 AM
slowcrx954's Avatar
Default Re: shift linkage not long enough (denraweb)
thanks for the replies i just dont want to set her down and have the motor settle and i just ruined and new shift linkage!
CHANCELLOR12
Jan 23, 2017 06:46 PM
vtecc
Jun 1, 2015 10:53 PM
CRX_GUY_123
14
Apr 5, 2004 09:13 AM
