Horn/Steering wheel control/SRS light problem
Hi.
I have a 2000 Acura 3.2TL. Recently the SRS light went off, after a few days the Horn stopped working and today the volume control and Cruise control on the steering wheel stopped working.
None of them work anymore. I have not taken my car to any mechanic yet, but spoke to Acura workshop...they are just trying to rip me off.
I am trying to see if there is any way I can find what to do. I have checked the fuses. There is a 'HORN' relay in the fuse box, have not been able to check that, cant find a new one anywhr except from Acura dealership. The guy at Autozone had a luk at the horn relay and said that it does not luk burn't.
Can someone help me out as to why al the 4things stopped workin al of a sudden. Are they interconnected? Do they have a common wiring? Wat is common between these 4things?
Thanks in advance.
Thanks in advance.
This is kind of a shot in the dark, but check the ground for those. I was looking for a little bit in ISIS and couldn't find a good picture but I think its in the steering wheel. Meaning if you remove the wheel the ground will be back in there some where. Since all these items are related it could be the ground.
Rob_KCMO
Apr 21, 2010 08:33 AM
