will small weld on press plate throw motor out of balance?
Old Sep 17, 2007 | 01:37 PM
97grnrs's Avatar
Default will small weld on press plate throw motor out of balance?
i got the supposed stage 4 press plate and clutch and it works fine but when i took it out i noticed the little tab u see in the pic is broke., there is 3 of them and 1 broke off.. so i welded it solid back on to where it went and i also put a lil weld on the other 2 incase they might break later on.. i havent put it back in yet but will doing what i did cause a big balance problem or no?? i dont know what the tab is exactly for but it was there for a reason i guess.. before weld, pic after i weld.. i painted weld white so u can see it better
Old Sep 17, 2007 | 04:05 PM
97grnrs's Avatar
Default Re: will small weld on press plate throw motor out of balance? (97grnrs)
anyone
Old Sep 17, 2007 | 08:52 PM
climb_on's Avatar
i guess best way to be sure is take it to a machine shop and see if they can balance it like they would a flywheel....
Old Sep 18, 2007 | 06:28 AM
zCivic's Avatar
Thats exactly what happened to my XTD pressure plate except I also broke the facing off and had that piece of that spring in the fingers. I would just get another one to be on the safe side. If I'm not mistaken what you have welded are release springs.
Old Sep 18, 2007 | 01:25 PM
97grnrs's Avatar
Default Re: will small weld on press plate throw motor out of balance? (zCivic)
well this is my 2nd one.. i had the stage 3 at first then that broke so i got stage 4 and still broke it.. i dunno im tempted to use it because i only had like 50 mile on it but i dunno if that weld would have a bad effect and if i can get away with welding that part solid like i did
Old Sep 19, 2007 | 06:26 AM
zCivic's Avatar
I would call a clutch repair place. I know here in TN a few places said they can replace the springs with heavier ones but I never asked if was the fingers or the other pressure springs like you broke. Nothing is worse then replacing a clutch in a crx trust me I know especially after only 50miles
Old Sep 19, 2007 | 01:46 PM
97grnrs's Avatar
replacing the clutch is cake .. but i just wanna know if ill be alright runnin this pressure plate or not the way i welded solid all 3 tabs??
Old Sep 19, 2007 | 11:58 PM
FarinaMotorsports's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs &raquo;</TD></TR><TR><TD CLASS="quote">well this is my 2nd one.. i had the stage 3 at first then that broke so i got stage 4 and still broke it.. i dunno im tempted to use it because i only had like 50 mile on it but i dunno if that weld would have a bad effect and if i can get away with welding that part solid like i did </TD></TR></TABLE>
Sounds like it's time to change brands. If your set on reusing this pressure plate I would send it to a reputable shop to be rebuilt.
Old Sep 20, 2007 | 12:28 PM
Bakeoff's Avatar
call the place you got it from. I've seen a clutch where the rivots weren't straights, so they would have rubbed the flywheel. Got a new disc shipped out. Then the PP litterally rubbed on the tranny case. Got a new PP.
Some places will work with you if you're experienced, talk to them calmly, and assure them it was installed correctly.
Old Sep 20, 2007 | 02:31 PM
97grnrs's Avatar
Default Re: (Bakeoff)
ha , good luck with xtd racing service.. i emailed them the same pics and he was like its probably nothing to worry about and would not do nothing.. its one of them chinese phone ppl that dont know nothing about the product..
Old Sep 22, 2007 | 02:41 PM
97grnrs's Avatar
im thinkin of trying one of the F1 racing.. stage 4 clutches.. says good up to 325 torque... maybe it will last a bit longer than xtd..
Old Sep 26, 2007 | 08:43 AM
chippy's Avatar
maybe you should try like comp clutches, exedy, act and not those ebay brands.
Old Sep 26, 2007 | 03:15 PM
zCivic's Avatar
Default Re: will small weld on press plate throw motor out of balance? (chippy)
yeah save up and get a good clutch kit. We all learn that lot of the time you get what you pay for and this is one of them. I am going to say the f1 is crap also. I would search them prior to purchasing seeing you have spent prob enough cash to buy an ACT or some other reputile brand
Old Sep 26, 2007 | 03:28 PM
standbackimapro's Avatar
Maybe you should quit buying shitty ebay clutch kits, and you wont have to fix them?
Old Sep 26, 2007 | 04:57 PM
97grnrs's Avatar
Default Re: will small weld on press plate throw motor out of balance? (standbackimapro)
i had a F1 stage 3 b4 and never broke it and it held a good amount of torque on my turbo ls hatch.... the XTD i wont buy again though the press plate sucks..
Old Jan 6, 2008 | 09:42 AM
Crx Jimmy's Avatar
I have that same XTD pressure plate, seems to be fine for the couple years it has been in.
Old Jan 6, 2008 | 03:36 PM
97grnrs's Avatar
Default Re: will small weld on press plate throw motor out of balance? (Crx Jimmy)
this is old. i got the act 4 puck now.
rstewartb18c
Jul 30, 2013 06:17 PM
95_red_dc
Sep 16, 2008 04:39 AM
hayabusa160
Jun 18, 2008 01:28 PM
97grnrs
May 7, 2007 04:34 PM
komat
May 30, 2006 05:55 PM
