Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
green 'key' light comes on; won't shut off even while driving
Old Sep 16, 2007 | 09:42 PM
menpachi's Avatar
Default flashing green 'key' light comes on; won't shut off even while driving
Can someone help? The green 'key in ignition' (?) light comes on (just started doing so) and stays on (flashing)as I drive. Once I had luck with shutting the car off; removing the key, and restarting. But now that doesn't help. It is really annoying (only that so far) but I am wondering what is the cause and does it signify anything besides a faulty light/connection....?
Old Sep 16, 2007 | 09:48 PM
toyomatt84's Avatar
Sanji
That deals with the immobilizer system. Have you ever replaced the keys at some point? Either way, it involves re-flashing your ECU, which the dealership has to do.
Old Sep 17, 2007 | 08:44 AM
dmorris05's Avatar
Default Re: (toyomatt84)
but its so fun to charge all that labor time to reflash ecus better than buying the new ecu and new keys and programming
Old Oct 30, 2007 | 01:29 PM
EM2K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">That deals with the immobilizer system. Have you ever replaced the keys at some point? Either way, it involves re-flashing your ECU, which the dealership has to do.</TD></TR></TABLE>
Hey Matt I'm having the same problem after my kswap and I don't know how to shut it off, I have a Hondata K-PRO any suggestions.
Old Oct 30, 2007 | 01:32 PM
fventura03's Avatar
Default Re: (USDMEM2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMEM2 &raquo;</TD></TR><TR><TD CLASS="quote">
Hey Matt I'm having the same problem after my kswap and I don't know how to shut it off, I have a Hondata K-PRO any suggestions. </TD></TR></TABLE>
in k-manager, i believe there is a setting to turn off/disable the immobilizer? maybe you have yours checked...
Old Oct 30, 2007 | 02:54 PM
toyomatt84's Avatar
Sanji
Default Re: (fventura03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fventura03 &raquo;</TD></TR><TR><TD CLASS="quote">
in k-manager, i believe there is a setting to turn off/disable the immobilizer? maybe you have yours checked...</TD></TR></TABLE>
Even with your immobilizer disabled, that light still flashes. You can remove the wiring from the starter key housing, flash the ECU to match your key's coding, or pull the wires from the LED behind the key light.
Old Oct 30, 2007 | 03:01 PM
fventura03's Avatar
oh hmm, cool
nspec_Cd5
Jan 17, 2008 06:06 AM
s2kkk
Honda S2000
10
Aug 12, 2007 12:27 PM
94ls
May 20, 2004 06:52 AM
SPOON_BeIgHtEeNsEe
Acura TL, RL & ZDX
Jan 29, 2004 03:47 PM
SLATER97EX
Nov 17, 2003 01:54 PM
