Vtec not working all the time..plz look.
This is kind of a weird problem. Everytime I go to hit vtec, you can't hear crossover at 5k but it starts pulling harder. 1st and 2nd, I can hear a slight crossover. 3rd-5th cant really hear anything. Could I be hitting vtec sometimes and other times no? Any real way on to test this?
btw: it's a b16a converted to obd1(dizzy, injectors, ecu), chipped ecu(vtec at 5k), new vtec selonoid, stock headers and exhaust. real quiet.
You know that if you are reving out the gears you wont really hear the crossover because if you rev out say second you are going like 60-65mph and you are already at 8000 rpm's so when you go into third your rpm's drop to say 6500-6700 or somewhere above 5000 rpm's. This means that you are still in vtec the whole time so no crossover occurs. Now if you are in third below 5000 rpm's and rev over that i dont think you would notice it as much as in first or second so you probably are hitting vtec the whole time and just not noticing it.
One thing you could do is have a buddy ride with you and check power at the ecu for the wire going to the vtec solenoid when you are in third-fifth and if it gets power it is working.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 »</TD></TR><TR><TD CLASS="quote">To have it operating at utmost effeciency, you shouldn't be able to here it anyway...</TD></TR></TABLE>
So if it has little sound, it's good?
btw, i tested the selonoid and it clicks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91EF_Si »</TD></TR><TR><TD CLASS="quote">
btw, i tested the selonoid and it clicks.</TD></TR></TABLE>
Depends on a few things, what kind of cams you have, what kind of intake you have, all things can effect the sound.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91EF_Si »</TD></TR><TR><TD CLASS="quote">I have stock everything. Just a filter on the throttle body. </TD></TR></TABLE>
You will be able to hear it in first, with out a problem. As for third and forth, you should already be in vtec no matter what if your going that fast.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks »</TD></TR><TR><TD CLASS="quote">
You will be able to hear it in first, with out a problem. As for third and forth, you should already be in vtec no matter what if your going that fast. </TD></TR></TABLE>
x2....but having a filter on the TB will lose power compared to having the stock airbox hooked up in most situations....
And with all your internals stock and all, the best way to check it is the method with a co pilot and a test light.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soulfly »</TD></TR><TR><TD CLASS="quote">the vtec sound varies depends on the motor oil you are using.</TD></TR></TABLE>
What the ****?
What the ****?
And with all your internals stock and all, the best way to check it is the method with a co pilot and a test light.</TD></TR></TABLE>
True. Plus
Vtec will be louder though cause the intake noise does not have to travel back threw the intake.
True. Plus
True. Plus
Thats what i tought.
True. Plus
What the ****?</TD></TR></TABLE>
not true?
not true?
not true?</TD></TR></TABLE>
Oil really has no effect
WTF????? are you on crack????????
civicking99
May 26, 2008 08:00 PM
