Clutch install, now got some problems
Old Sep 16, 2007 | 07:34 PM
all-mtr-teg's Avatar
Default Clutch install, now got some problems
I just rebuilt my gsr motor, and installed an ACTION CLUTCH 6-puck kit. Started the car, went into reverse, (no grinds), put it in first (no grinds) put it is 2nd, rpm just reved up, car would move. Pulled over, now car won't go at all. I can shift into gear with the car on or off, put when i let off the clutch and give it gas, car doesn't go, rpm's just wind up. Could my clutch disc be saturated with oil or slave or master cylinder bad?
Old Sep 17, 2007 | 08:45 AM
modded's Avatar
Default Re: Clutch install, now got some problems (all-mtr-teg)
1> Check that spring thingee that is located in the transmission behind where you put in the release bearing. (could be bent or compressed just try a different one)
2> are u running cable or hydro trans?? if cable adjust the the clutch cable until you feel it grab?
Old Sep 17, 2007 | 09:18 AM
Default Re: Clutch install, now got some problems (modded)
hydro clutch, and got a brand new spring on the clutch fork
Old Sep 17, 2007 | 09:34 AM
existanzcivicb20's Avatar
when you shifted to 2nd did you feel anything different like maybe your clutch broke. because once on my car one of the clutch bolts broke off and it got in the way of the clutch and it would not let me engage you should just pull the trans out it wont take long its better to be safe then sorry
Old Sep 17, 2007 | 09:43 AM
alterdcreations's Avatar
Default Re: Clutch install, now got some problems (existanzcivicb20)
do you have the right pedel pressure. is your slove leaking..did you tighten your slave to the tranny.....?
Old Sep 17, 2007 | 10:54 AM
Default Re: Clutch install, now got some problems (alterdcreations)
no clutch fluid leaks, all bolts are tightened, i hope its just the passenger side axle that popped out, i doubt the driver side popped out since it has that intermidiate shaft mount holding it in place. i'll try bleeding it once more when i get home from work, if its not just the passenger side axle that popped out or broke.
Old Sep 17, 2007 | 02:29 PM
modded's Avatar
Check the selector located where the shift rods go into located on the transmission.. Try moving them by hand and see if it switches gears.. do it with the car off you can hear it engage.. It might not be a problem with the clutch
Old Sep 17, 2007 | 03:11 PM
Default Re: (modded)
I can hear noise when i shift, when i depress the clutch and press the gas, i can hear the bearing spinning or making noise, rpms just go up, but car doesn't move, im gonna check to see if the axles popped out when i get off work
Old Sep 17, 2007 | 04:10 PM
Anti-Drama Queens's Avatar
check your axles and make sure none of them popped out
Old Sep 17, 2007 | 04:21 PM
1990_integra_DA9's Avatar
Default Re: (all-mtr-teg)
i had this problem...one of the springs broke on the clutch itself.
Old Sep 17, 2007 | 04:27 PM
Default Re: (1990_integra_DA9)
NOOOOO, brand new clutch kit
Old Sep 17, 2007 | 09:32 PM
Default Re: (Anti-Drama Queens)
sure enough, passenger side axle was popped out. thanks for the help
danno33
12
Sep 30, 2012 08:46 PM
bgm1958
Mar 12, 2012 10:34 AM
danno33
Jul 14, 2009 07:45 AM
d16dcoe45
Nov 10, 2006 01:06 PM
vietnamese0utlawz
Sep 17, 2006 06:53 PM
