Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Installing a remote starter
Old Sep 16, 2007 | 07:24 PM
kroze's Avatar
Default Installing a remote starter
I'm looking to install a remote starter on my 06 Civic DX (5 speed manual).
Installation should be extremely easy for it since it doesn't have power door locks or any factory alarm system right?
From what i've gather, it should be 7 wires total to connect.
- Power
- Ground
- Ignition
- Starter
- Tachometer
- Brake
- Parking lights
Am I missing anything? I bought this remote starter for a automatic but it shouldn't matter right?
Could someone shed some light onto where is the tachometer wire located? Ignition harness?
Old Sep 17, 2007 | 05:52 AM
FBPSidan's Avatar
Default Re: Installing a remote starter (kroze)
Is this also an alarm? If so you will need Door trigger/ trunk trigger/hood pin (if equipped) On mine the tach was under the hood
Old Sep 17, 2007 | 07:14 AM
Demonis's Avatar
not to mention clutch bypass
Old Sep 17, 2007 | 07:24 AM
FBPSidan's Avatar
Default Re: (Demonis)
oh yeah...duh, lol. Thats easy though
Old Sep 17, 2007 | 07:42 AM
redciv's Avatar
12volts white (50A) + ignition harness
Starter yellow + ignition harness
Second Starter N/A
Ignition blue + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory orange + ignition harness
Second Accessory red + ignition harness
Keysense pink - ignition harness
Power Lock green - dr kick or MICU, 34 pin plug, pin 28
Notes: The MICU (Multiplex Integrated Control Unit) is part of the fuse/relay box under the driver side dash. It has two plugs on the back of the fuse/relay box.
On the 4 door models, this wires changes from blue to green.
Power Unlock gray - dr kick or MICU, 34 pin plug, pin 27
Lock Motor blue 5wi DKP or fuse box, rear 14 pin plug
Unlock Motor yellow 5wi DKP or fuse box, rear 14 pin plug
Parking Lights+ red + dr kick or fuse box, top 42 pin plug
Parking Lights- gray or red - switch or MICU, 20 pin plug, pin 13
Hazards green + switch or fuse box, rear 16 pin plug
Turn Signal(L) blue + dr kick or fuse box, top 42 pin plug
Turn Signal(R) brown + dr kick or fuse box, top 42 pin plug
Reverse Light brown (4dr) or purple (2dr) + dr kick or fuse box, top 42 pin plug
Door Trigger see notes - ea kick or fuse box, top 42 pin plug
Notes: The LF door is green in pin 37. The RF door is lt. green in pin 3. The LR door is brown in pin 17. The RR door is gray in pin 2. Use all four wires and diode isolate each.
Dome Supervision pink - fuse box, rear 8 pin plug
Notes: Also found in a plug attached to the bottom of the fuse box.
Trunk/Hatch Pin blue - dr kick or fuse box, top 42 pin plug
Hood Pin lt. blue - pin sw or fuse box, mid 21 pin plug
Trunk/Hatch Release green + dr kick or fuse box, top 42 pin plug
Power Sliding Door N/A
Factory Alarm Arm orange - dr kick or MICU, 34 pin plug, pin 32
Notes: Meter this wire while turning the key in the driver door key cylinder.
On the 4 door models, this wire changes from pink to orange.
Factory Alarm Disarm brown - dr kick or MICU, 34 pin plug, pin 31
Disarm No Unlock see factory alarm disarm
Tachometer NOT blk/wht, black or yel/blk ac any ignition coil or fuel injector
Wait to start N/A
Brake Wire lt. green + switch or fuse box, top 42 pin plug
Parking Brake orange (4dr) or lt. blue (2dr) - parking brake switch
Horn Trigger orange - switch or fuse box, rear 16 pin plug
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: PKH34
Alternate Part1 #: 1100F/1100X
Alternate Part2 #: 556UW
Alternate Part3 #: DesignTech 20402
Alternate Part4 #: DesignTech 29402
Notes: Standard on all models. When using the 1100F or 1100X, a software change to 1100HA is needed. When using the 1100HA, follow the type 4 wiring. The ignition wire is yellow in pin 2 and the data wire is lt. green in pin 3.
Old Sep 17, 2007 | 07:46 AM
redciv's Avatar
there's all you need for your car starter bud.... don't forget that all civics have the transponder key in them and go to the nearest circuit city or best buy to buy a dei 556uw key box.... you need to give up your valet key.
now i havent done a starter on these yet, so i cant personally give you any tips or varify the wires i posted.
u need to hook up all the accesories and ignitions.. or your fuel pump/heaterblower etc... may not start up
Old Sep 17, 2007 | 07:59 AM
FBPSidan's Avatar
Default Re: (redciv)
The only words of wisdom i can give you is that they suck *** to do, lol. Took me like 7 hours for mine..but that also includes beer/pizza time
Old Sep 17, 2007 | 11:39 AM
redciv's Avatar
i install an average 100-130 starters per winter season. about. 400+ in all for my store
Old Sep 17, 2007 | 01:20 PM
kroze's Avatar
- I've bypassed the clutch the day I got the car with several miles on the odo.
- The civic DX does not have a transponder.
- This is just a remote starter (DEI 561r, no alarm)
Old Sep 17, 2007 | 11:18 PM
gus738's Avatar
Default Re: (kroze)
sounds too complicated weather or not its powerd you need to do bypass due to the car checking if key code and have one key taken away ..... best advice have cc/bb install alarm n starter so if they expletive up they'll take the blame!
Old Sep 18, 2007 | 07:47 AM
redciv's Avatar
Default Re: (kroze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kroze &raquo;</TD></TR><TR><TD CLASS="quote">- - The civic DX does not have a transponder.
well i guess you are good to go then
Old Sep 18, 2007 | 07:32 PM
JTaudio0212's Avatar
Redciv is correct with the wiring colors and such but got the wiring directly off of directechs.com which is usually right, but in my 07 Si it wasn't close, there was a lot of things that were way off. I don't know if the DX will be the same.
just a friendly heads up.
Old Sep 18, 2007 | 09:38 PM
89TSupra's Avatar
You don't need to give up any keys if you use an idatalink bypass module. It will take care of that for you.
you can order the multi series (ADS-TB) that works with many cars,
or order the solo series (ADS-TBSL-HA) which is actually cheaper and for Honda/Acura.
Just make sure the shop you buy it from installs the software on it because i belive they come shipped with no software on them.
More info at; http://idatalink.com/viewprod.asp?pid=3
If youre having trouble finding the right tach wire, i used the following;
The cylinder on the passenger side, there are 3 wires on the spark plug, use the one closest to the drivers side (cyl on the left, wire on the right)
but whatever you do do NOT use blk/wht, black or yel/blk on ANY cylinder.
kroze, i'm not sure if there is a difference between the Canadian models and the American ones but i know that here in Canada, all models are the same wiring and they ALL have a factory immobilizer.
If you have any questions on finding any of the wires you can message me or post it up because i just installed this into my car yesterday and i am an professional installer.
cheers!
Old Sep 19, 2007 | 03:16 AM
kroze's Avatar
The civic DX in the us also doesn't have: rear disc brakes, power locks, a radio or even a cassette player, arm rest (not even arm rest!), air conditioning, rear sway bar, steering wheel mounted control, steelie rims, etc...
basically cut every corner to save cost. So no transponder or immobolizer unless someone show me how to test it to see if i have it or not.
transponder is a chip on the key itself preventing just anyone from making a duplicate key and steal your car right? my sister's pathfinder have one and i think i know what it is.
Old Sep 19, 2007 | 06:25 AM
FBPSidan's Avatar
Default Re: (kroze)
I could of swore that all new cars have em... but i could be wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89TSupra &raquo;</TD></TR><TR><TD CLASS="quote">You don't need to give up any keys if you use an idatalink bypass module. It will take care of that for you.
Do you know if this module will work with a Viper alarm?
cheers!</TD></TR></TABLE>
Old Jan 5, 2008 | 10:47 AM
billydonscott's Avatar
Default Re: (kroze)
I could use some help installing a bulldog remote starter in a 2001 odd.
Thanks
I have the main unit, bypass and t harness, I cant find where the t harness plugs into the igintion switch.
Do I leave a key inside the bypass looped wire?
Please help.
Old Dec 9, 2012 | 08:51 AM
goneb4u's Avatar
redciv, have you installed a rs on a 2007 ridgeline ? if so any advice/info would be much appreciated.
Old Feb 9, 2014 | 01:57 PM
kcoons's Avatar
I want to install a remote start/lock on my 2006 Honda element so will I need a bypass unit too?
ef yu
Audio / Security / Video
Nov 14, 2009 11:18 PM
dafuzzbudd
13
Oct 4, 2008 03:52 PM
kroze
Sep 17, 2007 05:28 PM
slikz714
Jul 21, 2007 03:27 PM
truckramrod
Mar 5, 2006 07:00 PM
