k20 running issues
Old Sep 16, 2007 | 06:13 PM
willydc's Avatar
Default k20 running issues
after replacing the k20 and removing the turbo, the car is running rich, fouling plugs, and wont rev past ~4000rpm. The car is a 2002 civic si hatch, standard trans. What could this be?
Old Sep 16, 2007 | 06:58 PM
rick1574's Avatar
motor's in limp mode. when was the last time you changed your oil?
Old Sep 16, 2007 | 07:10 PM
willydc's Avatar
Default Re: (rick1574)
a brand new k20 was put in a week ago. it flooded on the way home from the shop actually
Old Sep 16, 2007 | 08:07 PM
WhiteOnRice's Avatar
Default Re: (willydc)
Where did you get a brand new k20? And all ep3's are standard.
Get it out of limp mode. What code is it throwing?
Old Sep 16, 2007 | 08:55 PM
willydc's Avatar
Default Re: (WhiteOnRice)
the car is not mine, its a friends. also, im a bmw guy, so i dont know hondas. how can i pull codes?
Old Sep 16, 2007 | 09:30 PM
JesSi's Avatar
You say that a turbo was removed, what engine management did it have when the turbo was on it? If this wasn't removed it's likely running a turbo tune on it and that's why it's running so rich. Does it have Hondata K-Pro? GReddy E-Manage? Cybernation Guardian? You need to give more information to get more indepth answers and ideas.
Old Sep 17, 2007 | 11:00 AM
willydc's Avatar
Default Re: (JesSi)
It was running GReddy E-Manage, and we drove it home to the apartment with it attached, but it was running very bad, and barely made it home. We took that off though and left the battery unplugged for 2 days to try and reset the ecu.
Old Sep 17, 2007 | 11:56 AM
Heh, you only need to wait like 2 minutes to let the ECU reset. It's instantly drained if you turn the headlights on or try starting the car with the battery disconnected. Other components (airbags) are said to take longer (30 minutes).
First off, get us the code it's throwing (AutoZone can give it to you free).
Old Sep 17, 2007 | 12:12 PM
willydc's Avatar
the problem is, we doubt itll make it down there and dont want to pay for a tow
Old Sep 17, 2007 | 12:15 PM
How to read codes on RSX/EP3 - http://www.ephatch.com/resourc...r.htm
Old Sep 18, 2007 | 05:40 PM
willydc's Avatar
The car seems to be throwing code 3. Which is MAP sensor voltage too high or low? Is this right? What's the fix?
Old Sep 19, 2007 | 09:56 PM
simonEp3's Avatar
I had the same problem in mine, it wouldnt rev past 4k rpm. The problem with mine was that i had a small oil leak i didnt know of, and there wasn't enough oil so the oil press. dropped and thats what was causing the problem. So you might want to check out the oil and make sure you got plenty in there and that there are no leaks.
CivSiClone_96
Sep 14, 2009 09:59 PM
93Sivic
May 29, 2007 07:35 PM
turbointegrakid
Aug 6, 2005 04:30 PM
StolenTeg
Jun 22, 2004 07:21 PM
GruvyTune
Nov 27, 2001 06:10 AM
