Cel on 93 gsr
After swapping professional products type r intake manifold and throttle body, my car has a cel #5 which is map sensor if I am correct. I used the firewall mounted map sensor and blocked off the throttle body spot for a map sensor. Everything work before the swap, is there something else I should look for?
Okay so I fixed the map sensors, but now it is throwing a code # 7 tps. I just reused the tps from my b17 throttle body, should I have gotten an ITR one?
Gabe Gamble
Aug 7, 2011 03:26 PM
EgSalad
Jun 6, 2007 12:12 PM
gaydm.accord
Feb 21, 2004 11:12 PM
