Any moved there battery?
Old Jun 17, 2002 | 07:32 AM
reXem's Avatar
Default Any moved there battery?
I am thinking of moving the battery to the rear cuz it will give me room to route my turbo piping....So what are the rules and regulations I have to follow? I heard it has to be fully enclosed and vented to the outside. Anything else?
Old Jun 17, 2002 | 07:51 AM
martini's Avatar
Default Re: Any moved there battery? (reXem)
you have to have an external battery cutoff to pass a tech inspection.
there is a thread in the drag racing forum you can look at.
Old Jun 17, 2002 | 07:56 AM
reXem's Avatar
Default Re: Any moved there battery? (martini)
thanks, didn't even think of looking there...
Old Jun 17, 2002 | 07:58 AM
Steve91's Avatar
Do yourself a favor and invest in a dry battery (Optima, etc). Make sure you anchor the battery to the floor well.
Old Jun 17, 2002 | 08:09 AM
reXem's Avatar
I can't find that post but where can this cut off go? Under the hood?
Old Jun 17, 2002 | 09:20 AM
CRXRageD's Avatar
about that battery cutoff switch, uh which regulations are you going by? Is this for a sanctioned drag racing body or for autox or what? I have a battery in a box in my hatch. I have no cutoff switch and I don't drag race for a living. I pass tech all the time when I go to the drag strip. It is also legal in E mod.
Old Jun 17, 2002 | 09:36 AM
dustin's Avatar
Default Re: Any moved there battery? (CRXRageD)
Sac raceway here won' t let you drag unless a relocated battery has a cutoff switch (not keyed) on the back of the car. It has to cut positive power from the battery AND from the alternator to literally kill the car.
Dustin
Old Jun 17, 2002 | 03:07 PM
CRXRageD's Avatar
Default Re: Any moved there battery? (dustin)
Dustin
That ****** sucks for you. I'm glad I don't have to do that bullshit. My car is a street car and a battery cutoff on my tail end could be disastrous. Any joker could come by and bam. The car would die. screw that strip.
Old Jun 17, 2002 | 03:08 PM
dustin's Avatar
Our decided solution is to get a spare right (or left) tail light, and mount a kill switch in it. Then when you go to the track, just swap out the taillight for the one with the kill switch in it.
Dustin
Old Jun 17, 2002 | 03:09 PM
martini's Avatar
you must have tech inspectors that don't know what the hell they are doing...or don't care.
Relocating a battery from the stock position (even if it's still in front of the firewall) requires a cutoff (positive terminal and alternator...four pole switch.) clearly marked and mounted to the rear of the vehicle. I think if you look around, most ALL sanctioning bodies require ths. Most tracks require it as well (even if just for a test and tune).
crxmanror
May 10, 2013 08:16 PM
boostedekhatch1
Jul 22, 2010 10:42 AM
DaveF
Feb 4, 2008 02:40 AM
turbo sol
Apr 14, 2003 10:48 AM
nihkon
Jun 24, 2002 04:17 PM
