where can i get a stock itr clutch for cheap
This is what I am running in my ITR
http://cgi.ebay.com/ebaymotors...ZWDVW
$243 for clutch and flywheel.
http://www.clutchcityonline.com should be ~$180.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baggedSIcivic99 »</TD></TR><TR><TD CLASS="quote">hey does anyone know where i can get a stock integera type r clutch for a good price?</TD></TR></TABLE>
Exedy/Daikin
http://www.ultrarev.com/produc...67027
Add it to your cart and it is $105+10 shipping. Works like a champ!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doostur »</TD></TR><TR><TD CLASS="quote">PM len
, not super cheap/discounted, but better than walking into your local dealer.</TD></TR></TABLE>
I checked a while back I think it will run you about $300 from them.
Exedy/Daikin
, not super cheap/discounted, but better than walking into your local dealer.</TD></TR></TABLE>I checked a while back I think it will run you about $300 from them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sp00led »</TD></TR><TR><TD CLASS="quote">
Exedy/Daikin
Add it to your cart and it is $105+10 shipping. Works like a champ!</TD></TR></TABLE>
Does the price change when you add it to the cart for whatever reason? If not, it's listed at $144.
Exedy/Daikin
As noted in the FAQ, which you're obviously too clueless to find
https://honda-tech.com/zerothread?id=1433240
:https://honda-tech.com/zerothread?id=1433240
Exedy/Daikin
I checked a while back I think it will run you about $300 from them.</TD></TR></TABLE>
Be careful, the exedy clutch you quote is for B18b and not Type R. Although they both are interchangeable, the KHC 13 http://www.ultrarev.com/produc...67023 is the right one and is more expensive.
Exedy/Daikin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stinkycheezmonky »</TD></TR><TR><TD CLASS="quote">
Does the price change when you add it to the cart for whatever reason? If not, it's listed at $144.</TD></TR></TABLE>
It gets cheaper when you add it to the cart.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bbqman »</TD></TR><TR><TD CLASS="quote">
Be careful, the exedy clutch you quote is for B18b and not Type R. Although they both are interchangeable, the KHC 13 http://www.ultrarev.com/produc...67023 is the right one and is more expensive.</TD></TR></TABLE>
Right i noticed that, the difference is 212 vs 219 size clutch disc but both are hydraulic clutchs. I'm not really sure which size the ITR stock clutch is but i'm pretty sure if it has the correct size pressure plate either will work. I know the 219 i pointed out will work because I am running one and have about 1000 miles on it.
Someone please point out the difference other then clutch disc size. I thought it was just a ITR markup.
Jmm0056
Dec 27, 2005 06:51 AM
91integraLSVTEC
Jul 2, 2005 04:06 PM
