water pump replacement
Old Sep 16, 2007 | 03:07 PM
metroya_performance's Avatar
Default water pump replacement
ok so I'm thinking of replacing my water pump, but I dont wanna tear it out until I find some documentation showing how to set my motor to TDC or whatever it is, but does anyone have the DIY link for doing that pump AND then redoing the timing?
Old Sep 17, 2007 | 03:31 PM
Lubo_25's Avatar
Default Re: water pump replacement (metroya_performance)
if youre just replacing your water pump and not the t belt get a white visible marker and dab a belt tooth and two cog teeth on each side of the belt dab and mark your crank pulley the same way along with the t belt then remove the t belt and pump...
i'd draw up a picture but maybe someone can explain it easier...
Old Sep 17, 2007 | 05:21 PM
egsleepercivic's Avatar
there is a mark on the crank shaft where the crank pulley that lines up with the mark on the block . there is also marks on the cam gears, line them up before you take off the belt. don't spin the crank or cams while you have the belt off. line the marks back up before you put the new belt on. Yeah I said new belt, you should go ahead and replace it while you have it apart.
gl
SlammedDC2teg
Aug 19, 2010 10:16 PM
unhappy_idle
May 22, 2006 10:16 AM
zracer240
Aug 1, 2005 10:07 AM
91tegrals
Jan 16, 2004 04:13 PM
turrismaldon
Oct 29, 2002 07:33 AM
