depinning ecu plugs
Old Sep 16, 2007 | 01:09 PM
894doorDX's Avatar
Default depinning ecu plugs
I am in the middle of my MPFI swap and I need to depin the eCU plugs and just can't seem to get the wire to come out of the plug.I have the two white clips removed but the wire refuses to come out.I am sure I could get the pin out but I'm not sure what I would tear up in the process so I thought I would just ask people who know much more than I do.Thanks
Old Sep 16, 2007 | 01:26 PM
hybrid1990crx's Avatar
Default Re: depinning ecu plugs (894doorDX)
get a small pick and look at the plug with the wires facing you. you will see a tab kinda deal on the pin try to get behind that and pull the wire out. its hard to explain without pictures. be careful not to mess up the hole though, the first time I wired my hatch for a b16 the pins ended up being very loose.
Old Sep 17, 2007 | 08:03 AM
894doorDX's Avatar
Default Re: depinning ecu plugs (hybrid1990crx)
thanks for the help man
Old Jan 18, 2008 | 12:07 PM
thedudefromjerz's Avatar
on which side of the pin?
Old Jan 18, 2008 | 12:15 PM
Default Re: depinning ecu plugs (thedudefromjerz)
the side with the tab on it. just look at it you'll see it.
Old Jan 18, 2008 | 12:23 PM
JustAnotherRex's Avatar
I found it was actually a hell of a lot easier to attack the pins from the front. They won't ever click into place *quite* right again, but it hasn't created any issue for me either. Along the center of the ECU clip you'll see little holes and you can stick a small screwdriver / pick / whatever in there and pull at the pin from the back, with some effort, get them free.
Old Jan 18, 2008 | 12:35 PM
Default Re: (JustAnotherRex)
yeah you can do it that way, but like you said it damages the connector and can cause poor terminal tension that turn in electrical problems and ses lights.
Old Jan 18, 2008 | 12:39 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
https://honda-tech.com/zerothread?id=1191491
rice crispies
Jul 5, 2005 08:07 AM
HeikDiesel
Oct 13, 2004 10:38 PM
Inkrazy
Mar 7, 2004 10:22 PM
FourthGenHatch
21
Apr 17, 2003 04:35 PM
Loaded Butane
Feb 23, 2002 05:08 PM
