whats normal op temp of a 01 prelude?
Old Sep 16, 2007 | 12:27 PM
DrivinVtec's Avatar
Default whats normal op temp of a 01 prelude?
anyone? also where can a get a lower degree thermostat
Old Sep 16, 2007 | 12:43 PM
117's Avatar
117
Why do you want a lower temp thermostat? It'll cause the engine to run slightly richer from what I've seen.
Normal operating temp should be 180F to 200F. On my track car, it stays below 200F, even in 100F+ Texas heat during 20 minute track sessions. I use a stock thermostat with a Fluidyne rad.
Old Sep 16, 2007 | 12:47 PM
DrivinVtec's Avatar
im turbo with stock cooling. im about to rebuild with in the month. shooting for 400whp. i dont think the stock cooling will hold uo. im ordering soem slim fans her shortly. but i think lower the thermo might help some. its 105+ here also. ridgecrest ca
Old Sep 16, 2007 | 12:48 PM
98vtec's Avatar
moderator emeritus
Default Re: (DrivinVtec)
datalogger says 190* at cruising, below 200* at idle on normal temp days, 205* temp (automatic fan switch) idle on hot days.
Old Sep 16, 2007 | 04:28 PM
preludefien
Guest
Posts: n/a
Default Re: (98vtec)
umm mines runs on a hot day at 180 in vtec and the fan kicks on at 220
Old Sep 16, 2007 | 05:04 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrivinVtec &raquo;</TD></TR><TR><TD CLASS="quote">im turbo with stock cooling. im about to rebuild with in the month. shooting for 400whp. i dont think the stock cooling will hold uo. im ordering soem slim fans her shortly. but i think lower the thermo might help some. its 105+ here also. ridgecrest ca</TD></TR></TABLE>
Stock thermostat and coolant and "water wetter" is the choice of champions
Old Sep 16, 2007 | 05:18 PM
DrivinVtec's Avatar
Default Re: (cb7-R)
so you think ill be okay just the way it is?
Old Sep 16, 2007 | 05:24 PM
98vtec's Avatar
moderator emeritus
why wouldnt you?
run water wetter if you are worried about it.
with a lower thermostat opening point you will have to adjust everything in the tune because it will no longer run at the same operating ECT that it was tuned for.
And honestly, i feel as though its just a cover up to the real problem. If you are overheating on the stock thermo then there is something wrong.
Old Sep 16, 2007 | 05:25 PM
117's Avatar
117
Exactly. If you overheat on a stock thermostat, a lower temp thermostat isn't going to help.
Old Sep 16, 2007 | 05:51 PM
DrivinVtec's Avatar
not really. doesn't mean something is wrong. FI cause alot more heat then NA. thats why things might get a little hot. just maken sure when its time to dyno i dont have problems. do the little things first.
Old Sep 16, 2007 | 06:28 PM
98vtec's Avatar
moderator emeritus
thats why you upgrade the radiator and fan, not what controls the opening temp of the thermo.
those things are for fanboys who just want to put "Mugen" or "Spoon" in their mod list.
Old Apr 30, 2008 | 07:27 PM
gstrudler's Avatar
It may not be necessary, but if you want one, Mugen makes one for $88 that you can get from http://www.kingmotorsports.com
Old Apr 30, 2008 | 07:38 PM
95greenlude's Avatar
Default Re: (gstrudler)
...you do realize this is a 7 month old thread.......
Steeve_Civic
Sep 24, 2013 05:04 AM
nothing_shocking
Jun 11, 2009 10:34 PM
5SpdH22
May 19, 2009 06:48 AM
MR Dan
Sep 9, 2005 11:17 AM
juicedricer
Jul 25, 2003 08:19 AM
