Venwood needs some guidance on creating a "Road Race" D16A6
Old Sep 16, 2007 | 12:16 PM
VenWood's Avatar
Default Venwood needs some guidance on creating a "Road Race" D16A6
I have rebuilt half a dozen of these engines for a stock class setup. I'm new to factoring variables & don't really posses the mass knowledge of the forum. This engine will be installed in a 1991 crx si F Production Car. The class allows
Mild Port, Polish,
Unrestricted Valve Guide, Seats, Cam Gear, Retainers, Keepers, Springs, Pistons
Valves In 29.0 Exhaust 25.0
Comp Ratio 12.0:1
110 Octane
Max Valve lift .450
Bore/Stroke 75.0 x 90.0
Must maintain stock rods.
I'm looking for cam grinds, manufactures of components & suggested builds that will take me to the edge but won't blow up. I will update to the top of my post consensus information relevant to my build. Learn me.
Components,
-Act Prolite Flywheel 8.4 Flywheel
-Piston ?
-Valves?
-Springs?
-Retainers/Keepers?
-Valves?
-Valve Guides?
-Cam Profile?
-Cam Gear?
-How to get to Comp Ratio?
Modified by VenWood at 4:38 PM 9/16/2007
Modified by VenWood at 5:30 PM 9/16/2007
Old Sep 16, 2007 | 02:02 PM
91' LS-VTEC's Avatar
Default Re: Design My Road Race D16A6 (VenWood)
I'm also interested in seeing what can be done with this motor.
Old Sep 16, 2007 | 02:35 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: Design My Road Race D16A6 (91' LS-VTEC)
contact BISI @ http://BISIMOTO.COM
he can get you the perfect cam for your set up and desired powerband.
Old Sep 16, 2007 | 03:52 PM
esteen2's Avatar
Default Re: Design My Road Race D16A6 (S@nt0s)
Do you have to use oem parts?
Old Sep 16, 2007 | 08:50 PM
Aquafina's Avatar
Default Re: Design My Road Race D16A6 (S2R Honda)
Might want to give KingMotorsports a call. They have a killer A6.
Old Sep 17, 2007 | 03:20 AM
VenWood's Avatar
I don't have to use oem parts. Just looking to call out anyone who may have a component mix they think is optimal.
Old Sep 17, 2007 | 05:06 AM
Furyof4's Avatar
Default Re: Design My Road Race D16A6 (Aquafina)
As said above
http://www.kingmotorsports.com
http://www.bisimoto.com
Also check out
http://www.d-series.org
Old Dec 8, 2019 | 04:32 PM
raffaelli's Avatar
Default re: Venwood needs some guidance on creating a "Road Race" D16A6
Whatever happened to this build?
Old Dec 9, 2019 | 12:38 PM
hondamark35's Avatar
Default Re: Venwood needs some guidance on creating a "Road Race" D16A6
doesn't look like the OP has been active in over 7 years.
found this, might be the one.
trobrah94
Jul 6, 2015 05:02 AM
vtecmissle
Jun 7, 2005 06:41 PM
TuningOptions
11
Jan 22, 2005 12:48 PM
shamoo
Sep 24, 2002 12:38 PM
