FUEL QUESTIONS? pump? injectors?
with a b18c in a Ef... should i upgrade the fuel pump? injectors? anything else to change fuel wise... FPR? Fuel Rail? running mostly stock motor... all bolt ons (I/H/E/IM) do i have to get it tuned if i change injectors and do i need different clips?
no keep the stock everything, you only need bigger injectors for forced induction. If you are boosted use the dsm 450's they plug right in to the stock clips and fit the stock rail.
EG-B20vtec
Nov 17, 2006 10:47 AM
jeremy.
Sep 29, 2003 05:35 PM
