won't start when hot
Old Sep 16, 2007 | 07:45 AM
zippie's Avatar
Default won't start when hot
We have an 89' civic hachback, very little tuning as of yet. Small problem, it won't start when the ambiant temp outside is over 90 degrees. Sounds strange I know but true. Does anyone have any suggestions? We put a hoodliner in thinking to insulate the motor from the tempature, didn't work.
Old Sep 16, 2007 | 07:53 AM
c0d0r's Avatar
Default Re: won't start when hot (zippie)
Might be the main relay, if you have a service manual look it up and check where it is, the contacts might be getting some unwanted resistance. Does the fuel pump prime?
Old Sep 16, 2007 | 08:55 AM
89s1's Avatar
Default Re: won't start when hot (c0d0r)
search "main relay" in our crx/civic forums.
you'll be suprised how common this is. its a fairly easy fix too.
Old Sep 18, 2007 | 06:42 AM
zippie's Avatar
Thanks for the info and the quick responses!
Old Sep 18, 2007 | 06:58 AM
GreenBean's Avatar
These are the four locations to solder, and then inspect all the rest and solder as needed...These four are the contacts for the fuel pump, which is what doesn't "power-on" when hot when the contacts are bad.
Borrowed from another web-site...
joecrx
Apr 3, 2007 11:23 PM
Hugsnkisses01369
Aug 18, 2006 02:46 PM
MJPana
Jul 30, 2006 09:27 AM
91d15bvtec
Jun 28, 2005 01:42 PM
AgentJam
Aug 15, 2004 03:07 PM
