99 Si motor into EG
Old Jun 17, 2002 | 03:59 AM
TodaSi's Avatar
Default 99 Si motor into EG
Anyone do this? Which rear engine mount did you use?
Old Jun 17, 2002 | 08:00 AM
singlecam screamer's Avatar
Default Re: 99 Si motor into EG (TodaSi)
well i think you use a rear gsr bracket and the stock civic mount,hope this helps
Old Jun 17, 2002 | 08:12 AM
DOHCtorTHRUST's Avatar
Default Re: 99 Si motor into EG (rudy 94 si)
im pretty sure the rear fits.... not that i've experienced it myself.... considering that its B series they should go together..... good luck.......
Old Jun 17, 2002 | 08:15 AM
stevecockrill's Avatar
Default Re: 99 Si motor into EG (DOHCtorTHRUST)
I had the shop hack up both the D series mount and the B series mount to make a "hybrid" mount ......works really well. Nice welds. I would have used a del Sol VTEC mount, but it was a Sunday and the dealership was closed and we wanted to finish up.
Works nice. probably stronger than stock!
Steve
Old Jun 17, 2002 | 08:22 AM
fowler!'s Avatar
No, it does not fit. It's too short.
Just buy a set of GSR mounts. That's the easiest thing to do. No point in welding all that stuff.
You can sell all the Si mounts for basically the same price of the GSR ones.
Old Jun 17, 2002 | 09:40 AM
TodaSi's Avatar
Default Re: 99 Si motor into EG (fowler)
Yes, the 99 Si rear mount bracket is too short....but the GS-R bracket does not bolt on my car....different hole locations on the engine side of the bracket (99 Si transmission/ 98 ITR block).
Old Jun 17, 2002 | 09:47 AM
That's what we found, and hence the need to cut and weld. I think that probably a del Sol VTEC bracket would work, but I have no idea if the subframe mount point is different between Civics, del Sols and Integras.......
Steve
Old Jun 17, 2002 | 09:56 AM
TodaSi's Avatar
Default Re: 99 Si motor into EG (stevecockrill)
DelSol huh? Anyone know this to work? Would rather get a new bracket than get mine all welded.
deemy72
Aug 30, 2009 01:49 PM
Metal Head
May 1, 2006 02:33 PM
nicknasty
Nov 19, 2003 04:17 PM
nicknasty
Nov 19, 2003 02:30 PM
lowboost civ
Mar 9, 2003 07:23 PM
