Makita buffer speed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4shizzle »</TD></TR><TR><TD CLASS="quote">i got a makita 9227c buffer. speeds are:
1- 600 rpm
2- 900
3- 1500
4- 2100
5- 2700
6-3000
what speeds should i be using to:
cut/buff
polish
glaze
wax
i will be using lake countrys orange, white, and grey CCS foam pads.
any other information will help. thanks</TD></TR></TABLE>
1 to spread product.
3 for compounding and polishing, MAYBE 4 for a fine polish with a white (non cutting) pad.
2 for wax, sealant, and glaze
you should never have to use 5 or 6.
I also recommend picking up a yellow lake country pad just to have it.
1- 600 rpm
2- 900
3- 1500
4- 2100
5- 2700
6-3000
cut/buff
polish
glaze
wax
I've had good results with:
400 spread product
1500 cutting
1200 polishing
hand glaze
hand wax
I always keep two spray bottles handy. 1 with water. 1 with 50/50 iso alcohol and water. I always dampen the pad w/water half way through compound's
life. I tend to over dampen the pad during the polishing phase.
50/50 to remove stubborn compound splatters (especially on girlfriends stupid MAC makeup box...don't ask
400 spread product
1500 cutting
1200 polishing
hand glaze
hand wax
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKFerioHawaii »</TD></TR><TR><TD CLASS="quote">I've had good results with:
400 spread product
1500 cutting
1200 polishing
hand glaze
hand wax
)</TD></TR></TABLE>
you can always use spray detailer to prime your pad and whatnot
400 spread product
1500 cutting
1200 polishing
hand glaze
hand wax
)</TD></TR></TABLE>you can always use spray detailer to prime your pad and whatnot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4shizzle »</TD></TR><TR><TD CLASS="quote">what kind of alcohol do i mix it with?</TD></TR></TABLE>
I'm sure he used rubbing alchohol.
but like I said, if you have any kind of spray detailer laying around, that is the preferred method.
nelson999
Sep 10, 2008 07:59 PM
