ecu
Old Jun 17, 2002 | 02:06 AM
86CRXSi's Avatar
Default ecu
anybody know what ecu was used in 87 teg, 87 rs????????are they different?????
i can't get any info in tegland...........
Old Jun 17, 2002 | 03:16 AM
Jared's Avatar
Default Re: ecu (86CRXSi)
What's an 87 RS?
Old Jun 17, 2002 | 03:58 AM
my_slow_civic's Avatar
Default Re: ecu (Jared)
What's an 87 RS?
87' Integra RS. Base model integra...
Old Jun 17, 2002 | 04:47 AM
crxfanatic's Avatar
New User
AFAIK, all 86-87 Teg 5-speed ecus are the same.
Old Jun 17, 2002 | 03:46 PM
86CRXSi's Avatar
Default Re: ecu (crxfanatic)
ok, cleared one question...............the other????????
what is 86-87 teg(5sp) ecu??????????
how do i find one??????
Old Jun 17, 2002 | 05:12 PM
USDM 4G VTEC's Avatar
whats this doing on the EF CRX forum?
what u talking about??
88-89 integras all had same ecu's just slight diff mods on engine
the 86-67 also....
on the 88-89 they had PG6 and PG7.... they are both for the first gen of integras... thats the ecu i got for my swap....
any more info go to http://www.hondaswap.com
peace
Old Jun 17, 2002 | 05:48 PM
86CRXSi's Avatar
Default Re: ecu (JDM EF9)
from what i understand 86-87 teg ecu are diff because the dist is vacume adv, like the 86-87 crx si.....................see where i'm going.....................want teg ecu for my rex but don't know actual code"pg6/7"??????????????????????
Old Jun 18, 2002 | 03:53 AM
crxfanatic's Avatar
New User
When I come into this forum, I come here to see CRXs, all CRXs, from 84-91, and Civics of the same years. That's why it's in here.
The 86-87 Tegs are different than the 88-89, which have electrical ignition advance. That's why you need an 86-87 Teg ecu, to match the old Si's electronincs and non elec vac advance...
I don't actually know the code, sorry. Since you're being harshed here, you may want to go to http://www.redpepperracing.com we are ahard core 1st gen enthusiasts there, I'm positive you can get a solid answer there, as I know several of the guys have that ecu. Also check out the crxmk1 mail list at egroups/yahoogroups. com, bunch of very helpful first genners there as well.
Old Jun 18, 2002 | 06:38 AM
crxfanatic's Avatar
New User
Some ecu info from Tom at RPR...
My 87 teg 5-spd is 37820-PG7-664 401 with an M in a circle. My 87 teg
manual is 37820-PG7-674 402 with an N in a circle.
HTH
driftam1
Oct 27, 2008 02:43 PM
Red_Si
Jul 11, 2002 07:34 AM
86CRXSi
Jun 17, 2002 02:01 AM
USDM 4G VTEC
May 13, 2002 06:00 AM
USDM 4G VTEC
May 13, 2002 05:59 AM
