Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
honda recall *9/14/07*
Old Sep 15, 2007 | 03:39 PM
3lo's Avatar
3lo
Default honda recall
Honda Motor Company announced plans to recall more than 180,000 Civics from the 2006-2007 model year Friday, in an attempt to fix a wheel-bearing seal that could lead to a wheel falling off the car.
Honda spokesman Richard Jacobs says all of the Civics were produced in Alliston, Ontario and that 80 per cent of the Honda vehicles are exported to the U.S.
The concern is that the seal where the antilock brake sensor is mounted to the rear wheel bearing might allow moisture and salt to leak in and cause corrosion.
The recall was sparked by two related complaints, including one in which the wheel came off the vehicle while it was being towed, though no injuries have been reported.
Owners are being notified of the recall and can contact Honda at 1-800-999-1009 for more information.
Old Sep 15, 2007 | 09:07 PM
s13_240sx_92's Avatar
Default Re: honda recall (3lo)
Good to know..
Old Sep 15, 2007 | 09:45 PM
97Ej6's Avatar
Default Re: honda recall (s13_240sx_92)
Thanks for the info.
Old Sep 15, 2007 | 10:33 PM
gus738's Avatar
Default Re: honda recall (97Ej6)
hmm thats alot of civics, dont we get our mail or something regarding this matter?
what about those civic oweners with a "salvage" or a rebuilt title? are those fu$ked
Old Sep 16, 2007 | 01:02 AM
EK k kay's Avatar
Default Re: honda recall (gus738)
lol i post this a day before two others post it and both of them get plenty of replies and one gets stickied. i guess no one saw mine lol.
Old Sep 16, 2007 | 03:55 PM
gdrum's Avatar
Default Re: honda recall (EK k kay)
anyone know if a rebuilt title civic would apply?
Old Sep 16, 2007 | 08:45 PM
Nighthawk R18's Avatar
Default Re: honda recall (gdrum)
well im lowered, they would still do it right?
and will they give me an alignment after?
thank you
Old Sep 16, 2007 | 09:16 PM
OmegaRed's Avatar
so if my civic is one of the recall ones, would i receive any kind of notice from honda?
Old Sep 17, 2007 | 07:14 AM
Default Re: (OmegaRed)
according to one of the links i read, Honda says that they will be sending out notices near the end of this month
Old Sep 17, 2007 | 07:28 AM
dshiromoto's Avatar
koo koo thanks
Old Sep 17, 2007 | 07:32 AM
Type X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay &raquo;</TD></TR><TR><TD CLASS="quote">lol i post this a day before two others post it and both of them get plenty of replies and one gets stickied. i guess no one saw mine lol.</TD></TR></TABLE>
i didn't stick this one up
BUT i put your % up to 101.
Old Sep 17, 2007 | 09:54 AM
twentywontowin's Avatar
Default Re: honda recall (Type X)
I just got my 07 Si Sedan on Wednesday. Luckily, looks like my VIN is out of the affected range. Only about the first 7500 Si Sedans are up for the recall.
Old Sep 17, 2007 | 10:00 AM
dt98gsr's Avatar
Default Re: honda recall (twentywontowin)
Good to know...
Aside from calling the 1(800) # is there anyway we can tell based on our VIN numbers if our car is part of this recall?
Old Sep 17, 2007 | 10:25 AM
Default Re: honda recall (dt98gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dt98gsr &raquo;</TD></TR><TR><TD CLASS="quote">Good to know...
Aside from calling the 1(800) # is there anyway we can tell based on our VIN numbers if our car is part of this recall?</TD></TR></TABLE>
Taken from the 8thcivic forums:
Safety Recall: Rear ABS Wheel Speed Sensor and O-Ring Inspection
Service Bulletin 07-055 / September 12th, 2007
Background:
During assembly, some wheel speed sensors may have been improperly installed and do not seal the hub assembly. Water may enter the hub assembly and damage the wheel bearing. In areas where road salt is used, the wheel bearings may corrode, which may cause the wheel to separate and fall off, increasing the risk of a crash." (being in Minnesota, this is just effing fantastic for me)
Vehicles Affected:
2006 Civic:
Coupe R18 : VIN 2HGFG1...6H500009 - 2HGFG1...6H584624
Coupe K20 : VIN 2HGFG2.5.6H700084 - 2HGFG2.5.6H713846
Sedan R18 : VIN 2HGFA1...6H500005 - 2HGFA1...6H528911
2007 Civic:
Coupe R18 : 2HGFG1...7H500001 - 2HGFG1...7H539744
Coupe K20 : 2HGFG2.5.7H700001 - 2HGFG2.5.7H706051
Sedan R18 : 2HGFA1...7H500001 - 2HGFA1...7H502258
Sedan K20 : 2HGFA5...7H700001 - 2HGFA5...7H707417
Corrective Action:
Inspect both rear ABS wheel speed sensors and their O-rings. If an ABS wheel speed sensor or the O-ring is damaged, replace the damaged part and the hub bearing unit on that wheel.
Old Sep 17, 2007 | 12:05 PM
thanks for that!
i hope they give me an alignment after checking it, because i need one.
Old Sep 17, 2007 | 12:55 PM
BAR296's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twentywontowin &raquo;</TD></TR><TR><TD CLASS="quote">
2006 Civic:
Coupe K20 : VIN 2HGFG2.5.6H700084 - 2HGFG2.5.6H713846</TD></TR></TABLE>
WooHoo!! I won!!...... i mean..... aw crap
Old Sep 17, 2007 | 01:35 PM
EK k kay's Avatar
Ahh dang mine is in the affected range. Called up my dealership and they said they won't have parts until mid october so they can't schedule me in. Hopefully I can get this done before I take it up to the mountain passes.
Old Sep 17, 2007 | 02:39 PM
dt98gsr's Avatar
twentywontowin thanks for the reply. I just checked my VIN# and I luckily outside of the affected VIN# range.
Old Sep 17, 2007 | 08:33 PM
originalg00kster's Avatar
i went to honda today and asked them about it.
they said they just heard about the recall...and that they will have to give me a call when they have the parts and stuff. because as of now. they have nothing to fix it with.
Old Sep 17, 2007 | 09:43 PM
HA0LEFIED's Avatar
im right on the tip of the last number HAHAHA yes im out of the vin range ;D
Old Sep 17, 2007 | 09:52 PM
Default Re: (HA0LEFIED)
mines affected. my dealer told me that Honda doesnt have a solution for it yet so i cant make an appointment to have it repaired. hmm
Old Sep 17, 2007 | 10:54 PM
SYTFU Tommy.'s Avatar
Default Re: (Nighthawk R18)
sister's fg1 is on recall . at least there isnt no salt around here in cali
Old Sep 17, 2007 | 10:56 PM
gus738's Avatar
uh huh thats great that alot of posters paid attention to this thread but netiher mine or gdrum or nighthawk questions were answerd!.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">hmm thats alot of civics, dont we get our mail or something regarding this matter?
what about those civic oweners with a "salvage" or a rebuilt title? are those fu$ked</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">anyone know if a rebuilt title civic would apply?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">well im lowered, they would still do it right?
thank you
Old Sep 18, 2007 | 07:52 AM
JayBinNyC88's Avatar
Damn im affected in that Vin range this sucks man now I got to go threw this hassle and the one before with the mileage not being the exact amount.. Question regarding that how much difference is the mileage has anyone been able to calculate how less it would be..
Old Sep 18, 2007 | 10:46 AM
FutureITR's Avatar
Default Re: (JayBinNyC88)
Wow...
