Bad shake/wobble on interstate
Old Sep 15, 2007 | 12:41 PM
zach1288's Avatar
Default Bad shake/wobble on interstate
I was on interstate 80 today and all of a sudden my car started to shake and wobble violently so i pulled over and thought my tire was flat or something. But i could not find anything wrong. So i kept going and it would shake alittle when doing 60mph but as soon as i would leave off the gas it would start again and you could feel and hear the thumping in the floor boards. That went on for 30+ miles then i slowly went away. So i get back on regular roads and i can feel alittle thumping but barely. What could it be? I was thinking the axle but im not sure.
Old Sep 15, 2007 | 12:45 PM
FW_EJ8's Avatar
wheel balance? bent wheel?
Old Sep 15, 2007 | 12:48 PM
zach1288's Avatar
Default Re: (TW_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TW_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">wheel balance? bent wheel?</TD></TR></TABLE>
It just came out of know where tho.
Old Sep 15, 2007 | 12:57 PM
starzofchaos's Avatar
Default Re: (zach1288)
Take it to a local tire shop and have them check your tires for balance, and while they are at it have them check for play in the tie rod's, and ball joints. If you have never replaced them in the last 35k-60k, chances are they have gone out. Tie Rod ends are a easy fix, just requiring you to take your car to get an alignment afterwards. Good Luck!
Old Sep 15, 2007 | 01:58 PM
instrument's Avatar
have you bothered to take your tires off and inspect them?
and also take a look in your wheel wells to inspect your ball joints/axles/tie rods?
Old Sep 15, 2007 | 02:22 PM
zach1288's Avatar
Default Re: (instrument)
My tires are new, why would it be a ball joint? It feels like the axle.
Old Sep 15, 2007 | 02:24 PM
Libertariat's Avatar
Ek Forever y0!
if it's all of a sudden then it's likely the ball joints or you got a "knot" in your tire.
Are the tires old?
Old Sep 15, 2007 | 02:31 PM
zach1288's Avatar
Default Re: (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">if it's all of a sudden then it's likely the ball joints or you got a "knot" in your tire.
Are the tires old?
When i shift at higher rpms it clunks too, the tires are like 8 months old.
Old Sep 15, 2007 | 04:04 PM
Ya, crawl under your car and look at the CV joints. My Jetta started doing that, then I saw one of the boots busted on the CV joint...
Old Sep 15, 2007 | 09:18 PM
zach1288's Avatar
Default Re: (starzofchaos)
Bump
Old Sep 15, 2007 | 09:25 PM
rivaladore's Avatar
the things that balance your tire can fall off..........start there.......inspect your rims....make sure they all have them on there........whens the last time you got an alignment....and check to make sure they all have the same/correct tire pressure....then check suspension parts
Old Sep 16, 2007 | 07:11 AM
zach1288's Avatar
Default Re: (rivaladore)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rivaladore &raquo;</TD></TR><TR><TD CLASS="quote">the things that balance your tire can fall off..........start there.......inspect your rims....make sure they all have them on there........whens the last time you got an alignment....and check to make sure they all have the same/correct tire pressure....then check suspension parts</TD></TR></TABLE>
I just dont understand if its a suspension part or wheel weight why wehn i was on the gas it would almost stop then if i let my foot off the gas it would start ?
Old Sep 16, 2007 | 06:16 PM
zach1288's Avatar
What would be the symptoms of a bad tie rod?
Old Sep 16, 2007 | 07:15 PM
zach1288's Avatar
bump
Old Sep 16, 2007 | 08:02 PM
zach1288's Avatar
What would be the symptoms of a bad tie rod???
Old Sep 16, 2007 | 08:07 PM
envee's Avatar
shaking at speed, but not a constant shake nor an extremely violent one. could be wheel bearing also. get it inspected by a mechanic, should be able to determine a problem quickly if you give them the symptoms.
Old Sep 16, 2007 | 08:16 PM
stock_honda_coupe's Avatar
Default Re: (envee)
This is simple. Put a floor jack under the lower control arm and jack the car up. Grab the tire and wiggle it side to side and up and down and check for play. do it to both sides. If you don't find anything replace the axle. Is the car lowered? cause that kills axles way faster than it normaly takes for them to wear out.
Old Sep 17, 2007 | 05:24 AM
zach1288's Avatar
Default Re: (stock_honda_coupe)
bump
Old Sep 17, 2007 | 07:58 AM
ek82's Avatar
it sounds like my car when i lower it......damn it i have the same problem i think
Old Sep 18, 2007 | 06:49 AM
zach1288's Avatar
bump
Old Sep 18, 2007 | 08:17 AM
hall97civic's Avatar
stop freaking bumping this thread. They told you to crawl under your car and look things over. Could be a lot of things. Personally I would think that maybe you tore a cv boot and that the cv joint is now bad. So stop bumping this thread and either go crawl under your car or take it to a mechanic.
charliecd5
Feb 16, 2015 01:44 PM
vtec25
Mar 4, 2008 10:58 PM
slkleltlclh
11
Nov 29, 2006 10:27 AM
black sohc civic
10
Jan 24, 2005 09:01 AM
Chicano
11
Jan 19, 2005 08:14 PM
