01have a question...flame away....how low can you go with a camber kit?
Old Sep 15, 2007 | 09:07 AM
JDM_FRONTIN's Avatar
* B A N N E D *
Default 01have a question...flame away....how low can you go with a camber kit?
i have an 01 itr and my setup is skunk2 springs with soon to have tokico illuminas and a front skunk 2 camber kit...me and my friend are going to put it all on and then im going to go get it aligned and the camber adjusted and i was wanting to know how low you can go with the camber adjusted???
thanks
Old Sep 15, 2007 | 09:11 AM
Dave_B's Avatar
Camber don't wear tires...
Toe does.
Old Sep 15, 2007 | 09:15 AM
JjuuN R's Avatar
Default Re: (Dave_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">Camber don't wear tires...
Toe does.</TD></TR></TABLE>
Not true...
OP, why don't you just put the suspension on and find out, it's worthless asking that kind of question...
Old Sep 15, 2007 | 09:16 AM
Dave_B's Avatar
Ok fine... mostly true...
More often than not though, it's the toe, not camber that people complain about causing premature tire wear.
Old Sep 15, 2007 | 09:19 AM
JjuuN R's Avatar
If your tires look like... ....../ /..........\ \..... you're going to get a ton of premature tire wear on the insides of the tires.
Old Sep 15, 2007 | 09:22 AM
Dave_B's Avatar
Default Re: (JjuuN R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JjuuN R &raquo;</TD></TR><TR><TD CLASS="quote">If your tires look like... ....../..........\..... you're going to get a ton of premature tire wear on the insides of the tires.</TD></TR></TABLE>
But when your driving...
The go / / or \ \ and so forth with turns...
Now if they are \ /
Old Sep 15, 2007 | 09:25 AM
JjuuN R's Avatar
Engrish?
Old Sep 15, 2007 | 09:28 AM
nsxtasy's Avatar
H-T Order of Merit
I say, lower your car until your ground clearance is down to about 1-2 mm and see how well it works.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">More often than not though, it's the toe, not camber that people complain about causing premature tire wear.</TD></TR></TABLE>
Dave's right. Yes, camber can cause uneven wear, but it's not usually as dramatic as the uneven and rapid treadwear that a toe misadjustment can cause.
Old Sep 15, 2007 | 09:33 AM
JjuuN R's Avatar
Default Re: (nsxtasy)
I know exactly what both excessive negative camber wear and excessive toe-in or toe-out wear look like on a tire, I just don't see how that's true...
I've ran -3.5F/-2.5R for years in the camber department, and all of my dozen or so sets of tires I've been through on the R were wore due to the negative camber wear...
Old Sep 15, 2007 | 09:38 AM
Dave_B's Avatar
How long were you on the tires before you noticed wear?
FWIW, I had an almost new tire (RR) and a toe issue. The tire lasted 2 weeks.
Cory, you are correct in some ways too... if after 15k miles on a set of tires you notice the insides are bald and outside still have tread that would be from camber.
* B A N N E D *
hha ok sorry guys ill just throw it on and put it right at the tire where i want it and go get it aligned and the camber adjusted
Old Sep 15, 2007 | 09:39 AM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">How long were you on the tires before you noticed wear?
Cory, you are correct in some ways too... if after 15k miles on a set of tires you notice the insides are bald and outside still have tread that would be from camber.</TD></TR></TABLE>
and thats the problem i had on my silver ls previous to my itr now and thats why i bought the camber kit
Old Sep 15, 2007 | 09:48 AM
JjuuN R's Avatar
Default Re: (EBAY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBAY &raquo;</TD></TR><TR><TD CLASS="quote">hha ok sorry guys ill just throw it on and put it right at the tire where i want it and go get it aligned and the camber adjusted </TD></TR></TABLE>
Exactly...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">Cory, you are correct in some ways too... if after 15k miles on a set of tires you notice the insides are bald and outside still have tread that would be from camber.</TD></TR></TABLE>
Haha Dave, try around 5000 miles.
That's just what happens when you run tires with 200-260+ tread wear with negative camber.
I could get a cheaper, longer lasting, harder compound tire, but naaaw...
Old Sep 15, 2007 | 09:49 AM
Dave_B's Avatar
That's not to bad then. My 2 weeks was around 400 or so miles. It was BAD!!!!!
new RR trailing arm and I was good to go.
Old Sep 15, 2007 | 09:52 AM
JjuuN R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">new RR trailing arm and I was good to go. </TD></TR></TABLE>
Old Sep 15, 2007 | 09:54 AM
Dave_B's Avatar
^ ??</TD></TR></TABLE>
When I bought my FBP DD, it had a RR tire wear issue.
It wasn't until I started measuring things and comparing sides that I came to the conclusion that the trailing arm itself was bent and causing my tire issue.
I replace the RR trailing arm and had the car aligned once more and all was good.
Old Sep 15, 2007 | 09:56 AM
JjuuN R's Avatar
Ahhh ok, see that's something I can't do, it's just me I guess, if I had to replace just one side, both sides would get brand new...
Old Sep 15, 2007 | 10:07 AM
Dave_B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JjuuN R &raquo;</TD></TR><TR><TD CLASS="quote">Ahhh ok, see that's something I can't do, it's just me I guess, if I had to replace just one side, both sides would get brand new...</TD></TR></TABLE>
Bushings and such were replaced on both sides for "freshen" it up. But a piece of metal IMO isn't a wear item so I didn't replace both. Only one was bent.
Old Sep 15, 2007 | 10:09 AM
JjuuN R's Avatar
I know, I'm just a very symmetrical type of person.
EF_9
Apr 9, 2008 02:45 AM
qhondak
Suspension & Brakes
Jan 31, 2008 08:07 AM
tolowhb
23
Nov 24, 2004 09:57 AM
SOHC_MShue
11
Oct 3, 2003 07:58 AM
spork sport
19
Mar 12, 2002 09:02 PM
