polished my wheels, need some guidance on getting them right.
Old Sep 15, 2007 | 05:07 AM
Tuner Eddy's Avatar
Default polished my wheels, need some guidance on getting them right.
i have a quick question.
I was polishing two of my si wheels yesterday. I first sprayed them with aircraft stripper, then got all of the clear and finish off using steel wool. I started out with the rough steel wool and finished with fine. I spent several hours on each wheel, then i used a meguiar's mag and aluminum polish.
After all of this, my wheels still don't look polished, they almost look like a factory si wheel as far as shine is concerned. Is it because of the polish i used or what?
Old Sep 15, 2007 | 05:44 AM
Tuner Eddy's Avatar
tttttt
Old Sep 15, 2007 | 05:57 AM
Genuine Rolla's Avatar
so, you went from steel wool to say...2000 grit..? you might wanna use something like 320, then 400, 800, 1000, and then finish with 2000. I've heard using a lil buffer helps a lot when polishing.
Old Sep 15, 2007 | 06:53 AM
SIRIUS's Avatar
Default Re: (Genuine Rolla)
^Yep. Did you wetsand with sandpaper or just use steel wool? I have a how-to somewhere here.
Old Sep 15, 2007 | 09:37 AM
Tuner Eddy's Avatar
Default Re: (FLAV)
i used just the steel wool. i went from 3-1-000
that's a harsh, medium and soft one.
Old Sep 15, 2007 | 09:39 AM
SIRIUS's Avatar
Default Re: (Tuner Eddy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tuner Eddy &raquo;</TD></TR><TR><TD CLASS="quote">i used just the steel wool. i went from 3-1-000
that's a harsh, medium and soft one.</TD></TR></TABLE>
That's not gonna cut it. You need to wetsand with sandpaper.
If you want high shine you'll neeed jeweler's rouge.
Old Sep 15, 2007 | 09:59 AM
Tuner Eddy's Avatar
Default Re: (FLAV)
okay, at this stage, what grit sandpaper do i need to use? and what is jeweler's rouge.
Old Sep 15, 2007 | 10:05 AM
Simple_Sauce's Avatar
https://honda-tech.com/zerothread/1259115
https://honda-tech.com/zerothread?id=804963
soundFX
Dec 11, 2006 11:28 AM
AlwayzSpoolin
Jul 29, 2006 01:55 PM
ek401
Jul 20, 2006 11:56 AM
thecorey
May 31, 2004 08:52 AM
Cosworth
Oct 5, 2001 08:03 PM
