when i push my clutch down I hear a springy noise
Old Sep 15, 2007 | 01:21 AM
SiRlos's Avatar
Default when i push my clutch down I hear a springy noise
whats that noise and how can i fix it? plz
Old Sep 15, 2007 | 04:52 AM
Glockwork's Avatar
take the rubber boot off of your clutch slave cylinder
grease where the slave cylinder pushes against the "lever" on the transmission
worked for me
Old Sep 15, 2007 | 05:00 AM
gamakichi77's Avatar
Default Re: (Glockwork)
i'm also had the same problem...any pics which part of it to regrease?
Old Sep 15, 2007 | 09:50 AM
95vxtealhatch's Avatar
pop your hood, find your slave cylinder, pull off the rubber boot your looking at. You'll see a rod coming out of the slave cylinder, it hits a fork ( that actuates the clutch), and on that fork there is a divot where the rod hits. Put some bearing grease or somthing there.
Old Sep 15, 2007 | 11:02 AM
Glockwork's Avatar
I'll get pics up tonight unless someone beats me to it
Old Sep 15, 2007 | 11:07 AM
Rikaro's Avatar
are you guys talking about the squeeking sound? i have that too
Old Sep 15, 2007 | 04:59 PM
SiRlos's Avatar
its annoying huh.. its like everytime you switch gears ppl look at you with that stare "your car is squeaky" ahahaha
Old Sep 15, 2007 | 05:40 PM
hmtcrxsir's Avatar
Default Re: (SiRlos)
It's the part where the ball joint is touching the Y Fork in the tranny. Grease it and bam your problem is gone. (well for me it did)
Old Sep 15, 2007 | 07:06 PM
crxricer66's Avatar
Default Re: (hmtcrxsir)
might jus be ur pedal under the dash, thats wut mine was
Old Sep 17, 2007 | 08:02 PM
SiRlos's Avatar
thanks no more squeakyness ^_^
Old Sep 19, 2007 | 01:16 PM
reheisler's Avatar
I had the same problem, lubed there, and it didn`t change anything. The creaky sound is definitely coming from the slave cylinder, so I think it needs to be replaced!
Anyone else tried lubing that joint this without success? What was next?
RH
Old Sep 19, 2007 | 06:45 PM
Default Re: (reheisler)
which parts in the picture shall i regreased?...is it inside both boots cover?
Old Sep 19, 2007 | 07:18 PM
Hittnthebz's Avatar
It looks like there is a grease fitting to the right of his pointer finger in that pic. Is it?
Old Sep 21, 2007 | 09:10 PM
hmtcrxsir's Avatar
Default Re: (Hittnthebz)
thats the nipple to bleed the slave cylinder.
Old Sep 21, 2007 | 09:25 PM
slaberdy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmtcrxsir &raquo;</TD></TR><TR><TD CLASS="quote">thats the nipple to bleed the slave cylinder.</TD></TR></TABLE>
yep.. that wouldnt do anything to make it squeak lol
Old Sep 22, 2007 | 03:31 AM
thanks...my problem solved...really appreciate that...
Old Sep 22, 2007 | 03:44 AM
Bevo's Avatar
Default Re: (gamakichi77)
haha thanks for this
Old Sep 22, 2007 | 04:28 AM
Historyg's Avatar
can someone put the pic up again i cant view it and i need to know were to lube please thanks...
Old Sep 24, 2007 | 11:41 AM
hmtcrxsir's Avatar
Default Re: (Historyg)
click refresh
jsohn
Honda Civic (2001 - 2005)
Aug 1, 2011 11:44 AM
zach1288
Mar 19, 2010 12:05 PM
kmksub
Nov 12, 2007 12:07 PM
2ndName
Dec 28, 2005 04:16 AM
xsnrgsr
Jul 13, 2003 08:23 PM
