D16z6 parts
Old Sep 14, 2007 | 08:48 PM
theERAisBack's Avatar
Default D16z6 parts
I busted a rod bearing in my D16z6 and i need a new crank rod and bearings? anyone know where i can get those parts upgraded so it wont happen again? and if anyone knows where i can get something to regulate my fuel beacuse i am not getting enough fuel to the engine.
Old Sep 14, 2007 | 08:53 PM
nicks-eg6's Avatar
Default Re: D16z6 parts (theERAisBack)
most performance places will sale a fuel pressure regulator . i have a b&m regulator and it works great. if you dont want that to happen again , i would honestly begin building the bottom end for whatever you plan on using it for. if not....junkyard, honda, or ebay.
goodluck
Old Sep 14, 2007 | 08:54 PM
nicks-eg6's Avatar
Default Re: D16z6 parts (nicks-eg6)
o..... i have the same engine as you do.
Old Sep 14, 2007 | 08:55 PM
i have a fuel pressure regulator but i need something else because i have a turbo and my compression is higher but just look at junkyard for parts, will the stock parts be safe for it?
Old Sep 14, 2007 | 08:56 PM
have any parts for it?
Old Sep 14, 2007 | 09:02 PM
nicks-eg6's Avatar
i dont right now. uuuummm fuel pump , injectors , and fuel rail should solve gas issues. a pull-a-part or salvage yard should have a 94 ex lying around . if you can try and find the entire motor, take it . that way you can start doing the headwork and building the motor with hardly no down time
Old Sep 14, 2007 | 09:32 PM
okay do you know how much one of those would cost so i have an idea? but what upgraded parts? im guessing those would be better
kaiem
May 1, 2019 01:01 PM
94_Teggy
Mar 2, 2009 02:45 AM
wfocrx
Apr 20, 2006 07:00 AM
Da K00l Aid Mayun
Sep 6, 2005 10:30 AM
