Door moldings coming off
Old Sep 14, 2007 | 07:43 PM
yoohoo's Avatar
Default Door moldings coming off
My door window moldings (#7/14 in the picture) are starting to come loose at the top. Is there a fix like an adhesive or glue I could use?
Old Sep 14, 2007 | 11:49 PM
bobjohnson's Avatar
Default Re: Door moldings coming off (yoohoo)
Use silicone. Pull the track lining away, get a small tube of silicone with a needle tip applicator, squeeze some into the back side of the molding, then press in. Roll your window up so it makes a good tight seal, and leave it alone for atleast an hour. Itll last until you decide to remove the seal later.
Old Sep 15, 2007 | 01:10 PM
yoohoo's Avatar
thanks! ill try that.
Old Sep 15, 2007 | 01:23 PM
markviiisvt4's Avatar
3M weather striping adheisive is what i used on my worked great. The silicone worked for a little while but it came down again.
ryyo
Apr 21, 2007 08:01 PM
Red_EM1
14
May 11, 2004 09:31 PM
hmongboyLS
Jul 17, 2003 11:50 PM
MikeMAN
Oct 26, 2002 08:45 AM
