Wiring power windows and locks on a 99dx...any guides?
Old Jun 16, 2002 | 11:18 PM
ZoobeaR's Avatar
Default Wiring power windows and locks on a 99dx...any guides?
I'm trying to figure out how I can wire power windows and locks on a 99dx.
I'm using doors off a civic ex, with the larger connectors (the dx connectors are two pins only). Where do I run the wires to, from the connectors?
Does anyone know if there are any online guides to this?
Thanks.
Old Jun 17, 2002 | 04:02 AM
TurboBumblBee's Avatar
Default Re: Wiring power windows and locks on a 99dx...any guides? (ZoobeaR)
Thanks.
good luck bro.. its a very difficult process but it can be done and sometimes worth it after its all said and done.. i did it to my roommates hatch.. he was lucky enough to get the ex doors w/ all wiring and then we had to go back to the junk yard agian to get the whole underdash wiring harness to make them work correctly.. get a helms or another good book that has wiring diagrams in it to complete it correctly.. basically the drivers side is the side that gets all the power and power goes to the passenger side through a relay that is in the fuse box under the dash.. if you need any other help IM me and ill try my best.. the hardest part is getting the wiring harness out of the car and into yours.
Old Jun 17, 2002 | 04:40 AM
92sleepR's Avatar
New User
First and foremost you will need a Helms manual. Don't even attempt it without those wiring diagrams.
You will need the chassis wiring that connects between the two doors. It isn't too hard to get it from a junked car. If you can get to the entire harness great but if you can't just pull the wires as far as you can from the passenger side and then cut them on an angle so you can match them up again later. Then just pull them (gently) one by one from the drivers side. It's not too difficult. You can solder them back together once you have them all. The harness connects to the fuse box, the stereo system at a plug behind the fuse box, and the power mirror switch (if you have it). You will need to remove the front fenders to install the door connector.
Of course you will need the door wiring harness as well and all the power stuf in the doors. I picked up everything from a junk yard for around $400.
Mike
foreverwefall
Jun 25, 2006 06:21 PM
JnyStylz
Nov 7, 2004 10:21 AM
romeirome1
Jun 8, 2003 08:38 AM
