CARVOX CX-999 HELP!!!
Old Sep 14, 2007 | 06:20 PM
sikefcrx89's Avatar
Loved
Default CARVOX CX-999 HELP!!!
well i bought this carvox cx-999 a couple months ago and have been trying to dry wire it the last couple days and i am getting no where on the power doorlocks part with the relay's and exact wire placement and such.. everything else i can do with ease but i am adding powerdoor locks to my crx and need these to work..not sure if some of you alarm pro's can get a schematic on this particular alarm and help me figure my problem out or not but i am in desperate need of some expert help..
Old Sep 14, 2007 | 07:32 PM
bpr0422's Avatar
Default Re: CARVOX CX-999 HELP!!! (sikefcrx89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sikefcrx89 &raquo;</TD></TR><TR><TD CLASS="quote">well i bought this carvox cx-999 a couple months ago and have been trying to dry wire it the last couple days and i am getting no where on the power doorlocks part with the relay's and exact wire placement and such.. everything else i can do with ease but i am adding powerdoor locks to my crx and need these to work..not sure if some of you alarm pro's can get a schematic on this particular alarm and help me figure my problem out or not but i am in desperate need of some expert help..</TD></TR></TABLE>
You currently have a CRX.. that didn't come from the factory with power locks..
You bought a budget alarm brain.. and want to wire it up?
And you can't read the wiring diagram that came or did not come with it?
And you got everything down but the lock/unlock..
The power of google brought me here: http://www.carvox.net/en/downloads.htm
2 Relays, reverse polarity: http://www.the12volt.com/doorlocks/page3.asp#arp
You have to run new 18ga wiring to the doors, either through the stock grommet, or drill a new hole and install a new grommet.. these 18ga wires will go to the relays...
where you put the relays, doesn't matter.. as long as they get power, ground, and the un/lock signal from the alarm brain.. it should be all good...
since the site is having a problem letting me dl the manual.. can't see the diagram atm... but sounds like you only have the alarm's un/lock leads, so just hook those up to the two relays as shown in the12volt's diagram
I recommend that you put the two relays next to the brain, so that you don't have too many extra wires going around your car...
I also recommend that you wrap the added door lock wires in slit loom, and make it look like stock wiring, keeps it clean...and helps hide your alarm wiring..
for more info just read suspendedhatch's cause for alarm - http://causeforalarm.thecarthi....html
Also If you want to reuse the stock grommets, all you have todo is pop the out first, if the tube is too small.. just replace it with slit loom, and tightly wrapped electrical tape.
that way when you open the door.. and look at the jam - it looks basically like stock wiring.
Old Sep 15, 2007 | 06:12 AM
sikefcrx89's Avatar
Loved
Default Re: CARVOX CX-999 HELP!!! (bpr0422)
yes thank you!! i did find the relay wiring on the12volt. but here is the exact wiring diagram of my particular alarm and how he wired it up..(i tried hi sway and still no go)http://www.zerotohundred.com/newforu...-an-alarm.html.
i am still kind of lost so anymore help is greatly appreciated
Old Sep 15, 2007 | 06:55 AM
fcm's Avatar
fcm
Old Fart
You do not need the 12volt.com wiring guide or the relays, door lock relays are built into the CX-999, use door lock diagram 1, [adding door lock actuators]
Connect the brown/black and white/black to 12V+ constant, [hot at all times]
Connect the violet and violet/black to ground, [chassis]
Connect the blue/black and the green/black to the actuator leads, [which of the two leads on the actuator you connect the blue/black and green/black to will depend on how you mount the actuator in the door, there is no wrong way, as long as it is to the same color wire on both actuators, if the doors lock when they are supposed to unlock and unlock when they are supposed to lock, just reverse the blue/black and green/black.
Did you not get a manual... http://www.carvox.net/downloads/HH6400e.pdf page 6. 94
Old Sep 15, 2007 | 07:31 AM
sikefcrx89's Avatar
Loved
Default Re: CARVOX CX-999 HELP!!! (fcm)
yes i did get the maual with it but its pretty vauge.. so i dont have to use a realy at all? i am kind of new to this type of complex alarm. i had the actuator working from the relays but as i stated before it was backwards.
Old Sep 15, 2007 | 07:39 AM
fcm's Avatar
fcm
Old Fart
That is correct, you do not need "off-board" relays as the unit has the relays built in, that's why there are 6 wires, [2 w/fuses] on the door lock harness.
As I mentioned, if they are working backwards just reverse the actuator connections. 94
Old Sep 15, 2007 | 07:54 AM
sikefcrx89's Avatar
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> That is correct, you do not need "off-board" relays as the unit has the relays built in, that's why there are 6 wires, [2 w/fuses] on the door lock harness.
As I mentioned, if they are working backwards just reverse the actuator connections. 94</TD></TR></TABLE>
thank you i hooked it up like you said and it works perfectly!!! i cant beleive it was that simple!! it was showing 87,87a and 30 on the diagram in the manual thats why i was trying to hook it up relay style.. but now i know they are not needed. now i can start putting it in the car!!
thanks!!
Old Apr 8, 2008 | 07:10 PM
nulfi's Avatar
Default Re: CARVOX CX-999 HELP!!! (nulfi)
hello,ANYONE CAN HELP ME I HAVE A CARVOX CX-999 ALARM AND WHEN I GOING TO TURN ON MY HONDA ACCORD 1997 WITH THE ALARM THE STATER IS CRAKING WHAT I HAVE TO DO, I NEED THE PROGAMATION.
Old Apr 9, 2008 | 05:50 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nulfi &raquo;</TD></TR><TR><TD CLASS="quote">hello,ANYONE CAN HELP ME I HAVE A CARVOX CX-999 ALARM AND WHEN I GOING TO TURN ON MY HONDA ACCORD 1997 WITH THE ALARM THE STATER IS CRAKING WHAT I HAVE TO DO, I NEED THE PROGAMATION.</TD></TR></TABLE> First, stop yelling, we can hear you.
Second, I am not sure what your asking. 94
Old Jan 26, 2010 | 11:42 PM
Trustnotic's Avatar
New User
Hello,
I have same problem with CR-V, 2006 y.
When I start remotly engine then starter runs to long even engine is running already. What should I do? Do I need some programming of cx-999 system as I can't find nothing for this problem.
How is possible to bybass original security sytem of 2006 y. Honda CR-V Executive, A/T?
Old Jan 27, 2010 | 05:44 AM
fcm's Avatar
fcm
Old Fart
Where did you connect the purple/white "tach" lead to?
The stock alarm can only be disarmed with the stock remote, I would pull the fuse for the stock alarm. 94
Old Jan 28, 2010 | 12:37 AM
Trustnotic's Avatar
New User
Purple/white connected now to RPM (blue wier) speedometer connektion.
Now starter runs ok. Only when engine is cold then it runs less (engine isn't starting)?!
Other problem is that when I start engine from remote and want to go to the car then engine shuts off if I open the door? It should shut off if ignition key isn't on and press brake pedal?!
I got it working also with original alarm. They are working same time and when I start engine remotly then it shuts off original alarm.
Old Jan 24, 2014 | 10:20 PM
restoboss's Avatar
i also have this alarm and when i auto start the starter runs to long then the car shuts off after a short time like 4-5 seconds then the alarm goes off .....any help would be greatly appreciated. and also if i auto start then hit the unlock right after the car will stay running but it wont let me unlock the doors they unlck then lock right away
Old Jan 24, 2014 | 10:23 PM
restoboss's Avatar
this is on a 99 civic i hooked up a keyless enrty kit with actuators on the three doors and hooked that up to the carvox 999cx auto start
justfurebay
Audio / Security / Video
Sep 28, 2008 10:43 AM
RACEPAK
May 4, 2007 12:01 PM
ug1yu
Jun 4, 2006 10:44 PM
Unjockable
Mar 8, 2005 12:06 PM
JDM_Honda_Fiend
Apr 26, 2004 08:54 PM
