help! skunk2 intake manifod install
Old Jun 16, 2002 | 10:35 PM
boot machine 5000's Avatar
Default help! skunk2 intake manifod install
i have a b18c in my ek and running on a si ecu. well i finished putting the manifold on and when i started it up the car's idle jumps around. its idles at 1000 and 2000rpm jumping back and forth. why does it do this? also anyone know how the t-fitting suppose to be connected. thanks.
Old Jun 16, 2002 | 10:57 PM
dogpile5's Avatar
25 Year Member
Default Re: help! skunk2 intake manifod install (Alvin)
that's happened a couple times to me when i did swaps for people. make sure you put the TPS and MAP sensor plugs back on correctly. both plugs are 3 prong, and will fit either sensor. also make sure you have a good seal between the TB and the manifold. later!
Old Jun 17, 2002 | 02:30 PM
MPower332TI's Avatar
Default Re: help! skunk2 intake manifod install (dogpile5)
this crap happen to me on a b16 with an itr manifold..we searched for leaks forever and finally found out it was a leak in the gasket..go over all ur bolts and make sure theyre really tight...also check all ur vacums and check ur coolant and bleed it..
daleSol
Feb 13, 2013 09:08 AM
oranginal
Oct 4, 2009 05:46 PM
Ep1dem1c
Jul 18, 2007 10:03 AM
frostt3ch
13
Apr 2, 2006 05:41 PM
boot machine 5000
Jun 17, 2002 11:05 AM
