Disabling e-brake and 0mph to lower top while moving
Yeah I was crusing around 70 mph (maybe faster i dont know I was drinking and
keeping my eyes on the hooker I had picked up and had beside me that was trying to
get in my pockets) and I thought how cool would it be to be able to lower the top now?
So can anyone tell me how to disable that function?
Modified by Driftonator at 5:28 PM 9/14/2007
Have fun. ROFL.
It's actually the speed sensor not actually the ebrake. You'll just need to put the ebrake to one click and boom it goes down or up.
BRB......................*runs out and tries it*
*comes back - thump*........ ummmmm yea so anyone else?
Papasmurf, you should tell me if you know because you wouldn't like me when Im angry!!!" - David Bruce Banner.
Modified by Driftonator at 7:31 PM 9/14/2007
Sweet...
Anyways.
- Pull the bottom dash panel on the passenger's side (connected by 6 clips)
- You'll see two plugs with a bunch of wires connected to this black "control box"
- Pull out the plug on the right. should have 4 wires on the top and 6 on the bottom I believe (the smaller of the two plugs)
- Then cut the black/white wire. (it should be on the bottom row, second from the left)
- Tape up both ends with electrical tape.
You should be set to go. This allows you to put the ebrake on one click and put the top up or down while rolling.
Now you could go all the way, and cut the ebrake wire also so you don't have to put the ebrake on one click, but I would suggest against that, just due to safety reasons.
Anyways.
If this is a trick its a pretty elaborate one. One that you really thought out well to make
me go through all this trouble to probably in the end short out my car.
Papasmurf = evil.
Papasmurf = evil.
no its not, i do it while rolling all the time. tis the e-brake in my 04. i start it while at like 2mph to make sure im done by the time the light changes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_ruler »</TD></TR><TR><TD CLASS="quote">no its not, i do it while rolling all the time. tis the e-brake in my 04. i start it while at like 2mph to make sure im done by the time the light changes
huh?
</TD></TR></TABLE>huh?
wtf are you saying LOL
dont do this trick above 35 mph
</TD></TR></TABLE>wtf are you saying LOL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraLs94Cam »</TD></TR><TR><TD CLASS="quote">all you do is cut two wires and that is it?</TD></TR></TABLE>
You cut one wire. As I stated, I suggest against cutting the ebrake wire due to safety reasons.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmdr430 »</TD></TR><TR><TD CLASS="quote">http://www.s2ki.com/forums/ind...38773</TD></TR></TABLE>
Thank you very much!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Driftonator »</TD></TR><TR><TD CLASS="quote">
Thank you very much! </TD></TR></TABLE>
You see, my directions where 100% accurate.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenadict »</TD></TR><TR><TD CLASS="quote">I also noticed that even with car stopped and e-brake engaged, if the car is in gear the top won't move.</TD></TR></TABLE>
Car being in gear doesn't not matter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf »</TD></TR><TR><TD CLASS="quote">
you're my boy blue!
</TD></TR></TABLE>you're my boy blue!
I only cut the white wire with the black stripe and it worked.. Very nice free mod to do that looks alot better when moving at 5 or 10 mph.
What method did you use to remove the panel w/o breaking it?
(Im going to try it but I dont want to break the clips or panel)
I read that by pulling the panel straight toward the passenger seat?
Also how could I remove the speed sensor wire without cutting the wire i.e. leaving the metal connector still attached so i can replug at a later date?
