DIY: LS Mesh black w/ red lip
just got back from pep boys, dont have time to do it today but i will make posts as i go along, cant wait to see how it comes out, and ill keep this thread updated.
50 bucks total, not bad
***9/19/07
teaser pic so far. will post write up when i finish. still got that red lip to go
teaser
Modified by brzrkr at 3:23 PM 9/19/2007
Modified by brzrkr at 7:12 PM 10/19/2007
***9/19/07
teaser
i just sprayed my ls meshies.
the biggest worry for me was whether to sand down the machined rings or not. i got trough half of it and then test sprayed on another peice of aluminum to see how thick the rim paint is.
its extremely thick and runny. so i decided to just scuff the rim with 400 after stripping it with aircraft stripper and then spray
make sure you do reallly light coats you dont want full coverage untill the third or fourth coatt.
i used bronze and it turned out quite well ill get some pictures up asap.
also mine started with major curbage all around the ourter lip so i took a palm sander with 80 and worked my way up to 800 till it was smooth.
man i did this to my meshies i did blue....taping was just a bitch but i have a nice lip i did it to reduce the signs of oxidation on my meshies since it was already black with a polished lip.....but the blue has worked and i used some anodized "metalcast?" spray and a mixture of rustoleum "metal" paint and it gave it a anondized blue but not too purplish finish
phew, taking a break from this. so far all rims are black. waiting for the paint to dry, then taping that b!tch up and painting my lip red
and dam my back hurts. bending over to mask off lip n all that crap got me beat
Duplicolor paint is very brittle since its lacquer based. I painted some rims with it not too long ago. I don't think the finish will last long at all.
Simple
Jun 11, 2005 06:03 PM
kapoosh valve
Apr 26, 2005 10:19 AM
good luck
