Removing Cam caps
Old Sep 14, 2007 | 12:52 PM
vinuneuro's Avatar
Default Removing Cam caps
Took the bolts and the cam cover plates off, but the cam caps seem to be stuck in place. Is there anything more to removing them? Mallet?
Old Sep 14, 2007 | 01:03 PM
117's Avatar
117
Default Re: Removing Cam caps (vinuneuro)
They're positioned by dowel pins that fit fairly tightly in the head and cam caps.
Old Sep 14, 2007 | 01:06 PM
vinuneuro's Avatar
Default Re: Removing Cam caps (117)
Somehow pry?
bluedlude's Avatar
you should be able to to wiggle the cam a little and get enough room to get under the caps to fit something. then just work them side to side.
Old Sep 14, 2007 | 01:24 PM
117's Avatar
117
I usually use a wide screwdriver to pry VERY gently on the tabs on the caps. Cover anything that you pry against with a shop towel. DO NOT PRY ON ANY MACHINED SURFACES.
Modified by 117 at 4:43 PM 9/14/2007
Old Sep 14, 2007 | 01:31 PM
nonvteclude's Avatar
Default Re: (117)
there are little tabs that come out so you can wedge them out. its a lip that faces forward on the exhuast side and believe to the rear on the intake side that you can use to pry them off
Old Sep 14, 2007 | 01:35 PM
vinuneuro's Avatar
Default Re: (nonvteclude)
Thanks guys.
Old Sep 14, 2007 | 04:39 PM
lude98SH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvteclude &raquo;</TD></TR><TR><TD CLASS="quote">there are little tabs that come out so you can wedge them out. its a lip that faces forward on the exhuast side and believe to the rear on the intake side that you can use to pry them off</TD></TR></TABLE>
thats how i got mine off. Just be gentle and wiggle them alittle, they will come off.
Old Sep 14, 2007 | 04:52 PM
vinuneuro's Avatar
Default Re: (lude98SH)
Yep, got them out using the tabs. Not bad at all using them.
Tim_EG
Oct 8, 2012 08:01 PM
overrev_it
Mar 31, 2010 04:54 AM
freeagent32
12
Jul 13, 2005 03:55 PM
asubennett
15
Jul 9, 2005 03:05 PM
216.226.142.95:27016
Jun 27, 2003 10:22 PM
