Honda S2000 Honda S2000
Will a F22c block fit the f20c?
Old Sep 14, 2007 | 10:21 AM
s2k-ap1's Avatar
Default Will a F22c block fit the f20c?
i have an 01 s2k f20c but fucked up the piston, and crankshaft. A guy is selling me a block with everything but its from a f22c.. would any of u guys b able to tell me if it does.thnx
Old Sep 14, 2007 | 10:42 AM
papa5murf's Avatar
Default Re: Will a F22c block fit the f20c? (s2k-ap1)
So in other words you want to put an f22c short block and mate it up to an f20c head? Yes it's doable, yes it will work (how well, well that all depends).
Old Sep 14, 2007 | 10:46 AM
s2k-ap1's Avatar
Default Re: Will a F22c block fit the f20c? (papa5murf)
well all i know is that the f22c overheated, but the block is good.
Old Sep 14, 2007 | 10:50 AM
s2k-ap1's Avatar
well all i need is the piston, connecting rod, and the crank..but the crank its self is 1000..and this guy is selling me the block for 500.
Old Oct 17, 2007 | 02:03 PM
asarraf's Avatar
i have a question along these lines too... i have a 2003 honda s2000, and my motor popped on me. I want to get a brand new motor. I found a good deal on a 2005 motor which is the 2.2 liter one. Has anyone done a motor swap with thw 2.0 liter and the 2.2?
Do you need any extra parts? or is the f22 engine a direct bolt?
Also, if i swap a f22 engine in my car, do i need the transmission as well? Or can i use my old transmission which is a 2003 from the f20 motor?
Old Oct 17, 2007 | 02:14 PM
Black S2K's Avatar
you can run your ap1 transmission with the f22 motor but you wouldnt feel the advantege of the 2.2l. The ap2 transmissions' 1-3 gears are shorter then the ap1. I would not recomend running a ap1 tranny with the f22 motor.
but the ap2 tranny with a f20 is a whole diff story.
Old Oct 17, 2007 | 02:20 PM
KingVR's Avatar
F20c and F22c have the same 87mm bore, but the stroke went from 84mm to 90.7mm in the 2.2L and yes, the external dimensions of the block are identical, so the tranny from all years will fit either block.
Cranks may not be interchangeable depending on which way you want to go, and with the different stroke, the rod length or the pin location may be different, so I do not know what is swappable there.
Old Oct 17, 2007 | 02:21 PM
KingVR's Avatar
Default Re: (Black S2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black S2K &raquo;</TD></TR><TR><TD CLASS="quote">you can run your ap1 transmission with the f22 motor but you wouldnt feel the advantege of the 2.2l. The ap2 transmissions' 1-3 gears are shorter then the ap1. I would not recomend running a ap1 tranny with the f22 motor.
but the ap2 tranny with a f20 is a whole diff story.</TD></TR></TABLE>
Why would a LOWER RPM (F22c) engine get the SHORTER gear set? It should be the other way around.
Old Oct 17, 2007 | 03:24 PM
ITRbroham's Avatar
shit post warrior
Default Re: (KingVR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KingVR &raquo;</TD></TR><TR><TD CLASS="quote">
Why would a LOWER RPM (F22c) engine get the SHORTER gear set? It should be the other way around.</TD></TR></TABLE>
You need to ask Honda engineers about that.
Old Oct 19, 2007 | 12:51 AM
riceball777's Avatar
i was thinking the same thing
a lower rpm more displacement more torque engine should have larger gears
Old Oct 19, 2007 | 06:07 AM
purehonda's Avatar
Make sure to get it decked in case it warped from overheating
Old Oct 19, 2007 | 07:44 AM
KingVR's Avatar
Default Re: Will a F22c block fit the f20c? (purehonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purehonda &raquo;</TD></TR><TR><TD CLASS="quote">Make sure to get it decked in case it warped from overheating</TD></TR></TABLE>
If a head is warped, decking it will not solve the mis-alignment of the cam bearings if it's severe enough. An experienced machine shop can straighten a warped head in an oven by mounting it to a thick steel plate and bolting it down with shims in the correct location to influence it back to straightness again.
Old Dec 9, 2007 | 01:43 PM
gzob's Avatar
Default Re: Will a F22c block fit the f20c? (KingVR)
Why do you mention the cranks are not interchangeable? The F20C and F22c pistons have the same compression height, so one can use the F22C crank and rods in a F20C block with F20C pistons and have a nice and cheap stroker kit with around 11.5 compression. This is almost what major brands do anyway for their stroker kits.
Old Dec 9, 2007 | 02:01 PM
LAS2K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2k-ap1 &raquo;</TD></TR><TR><TD CLASS="quote">well all i know is that the f22c over-rated, but the block is good.
Fixed
Old Dec 9, 2007 | 05:37 PM
envee's Avatar
rofl @ LAS2K
my question is, since the piston speeds on the f20 and f22 are similar with a 700 rpm difference in redline, can you rev a f22 block with a f20 head to 9k? i know this would raise the piston speed up but the f22 is something like 200 FPM slower at 8300 than the f20 at 9k.
Modified by envee at 4:55 PM 12/10/2007
Old Dec 9, 2007 | 08:03 PM
ABCVTEC's Avatar
Default Re: (envee)
I wouldn't do it. Unless you want a rod through the block.
Old Dec 10, 2007 | 08:05 AM
envee's Avatar
I would think that it wouldn't be a rod problem. Aren't the oem rods forged? But i suppose at pistons speeds of over 4k FPM anything can fail.
Modified by envee at 4:53 PM 12/10/2007
Old Dec 11, 2007 | 07:18 PM
stev3's Avatar
so if you were to mount the f22c onto the f20c
its like a mini Frankenstein motor?
would it still retain the same power, just with more torque?
Old Dec 12, 2007 | 12:38 AM
TheDancingPill's Avatar
Default Re: Will a F22c block fit the f20c? (LAS2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LAS2K &raquo;</TD></TR><TR><TD CLASS="quote">
Fixed </TD></TR></TABLE>
haha
Old Dec 16, 2007 | 06:28 PM
vollrathian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asarraf &raquo;</TD></TR><TR><TD CLASS="quote">i have a question along these lines too... i have a 2003 honda s2000, and my motor popped on me. I want to get a brand new motor. I found a good deal on a 2005 motor which is the 2.2 liter one. Has anyone done a motor swap with thw 2.0 liter and the 2.2?
Also, if i swap a f22 engine in my car, do i need the transmission as well? Or can i use my old transmission which is a 2003 from the f20 motor?</TD></TR></TABLE>
http://drive.gtchannel.com/?c=127&a=1503 in the second video they are talking about the spoon stroked f20 with the ap1 tranny is a better setup
Old Mar 27, 2010 | 05:16 AM
S2kFreak's Avatar
Bump for this "?" to be answered..
Srry for digging back up this OLD OLD OLD thread.
Old Mar 27, 2010 | 10:11 AM
S2kFreak's Avatar
Bump!!!!
Need answer
Old Mar 31, 2010 | 07:55 AM
S2kFreak's Avatar
Bump!! i need answer asap
Old Mar 31, 2010 | 08:25 AM
White Smoke's Avatar
i my honda
Global Mod
The question... "would it still retain the same power, just with more torque?"
The answer is no! A setup like this would require a custom tune that would produce more power and torque over the factory F20.
Old Mar 31, 2010 | 12:42 PM
JUSTINTHECOASTI's Avatar
Yes the 05 ap2 engine will work with on 03 trans all direct bolt up, you will need to get an 00-01 ecu or vafc for fuel and you'll have to adjust your fuel rail, it'll be a good time to upgrade your clutch as well if you havent
