Suspension & Brakes Theory, alignment, spring rates....
Anybody have experience with the Cusco Lower Control Arm Braces????
Old Sep 14, 2007 | 07:49 AM
90da4dr's Avatar
Loved
Default Anybody have experience with the Cusco Lower Control Arm Braces????
I see there are two versions they have. Type I (2 point) and Type II (4 point). I just want to know if there is a significant difference (rigidity) between the 2 point and 4 point braces. Or is it worth it??
Old Sep 15, 2007 | 05:56 AM
90da4dr's Avatar
Loved
Default Re: Anybody have experience with the Cusco Lower Control Arm Braces???? (90da4dr)
ttt
Old Sep 15, 2007 | 09:13 AM
turbogeekDA6's Avatar
i had the 2 point bar on the da for a while but i recently took it off because it was in the way of my new header. i never could really tell that much of a difference because i installed it at the same time i changed the bushings in the whole car. a lot of racers are not even running a fltb. its really not that important of a piece as the car doesnt flex that much down there. the fusb is much more important, and the rear lower tie is the lower tie that you really need on an integra. i got it bc i wanted to have "everything" on my car. if thats the aim then its not a bad buy. it looks good, but it hangs kinda low. if i even go turbo and get a custom dp that will go over it ill put it back on. who knows. good luck with it. if u find the 4 pt brace for the da then post a link. id like to check it out.
Old Sep 17, 2007 | 05:26 AM
90da4dr's Avatar
Loved
Default Re: Anybody have experience with the Cusco Lower Control Arm Braces???? (turbogeekDA6)
Thanks for the reply. My bad i never stated what car i own. I own a g20 now. I just wanted to know if these lower control arm braces did anything in general. I know its chasis specific, I just wanted a general census.
Thanks
tamadrummer1120
Jul 13, 2009 04:57 PM
chb93
Feb 28, 2009 11:19 AM
thomst4R
Suspension & Brakes
Jul 17, 2005 06:20 PM
skyliner186
11
Dec 29, 2003 08:39 PM
ITRbroham
Oct 10, 2001 11:23 PM
