Switching from obd1 to obd2?
Old Sep 14, 2007 | 07:00 AM
tpdc2's Avatar
Default Switching from obd1 to obd2?
Ok so I have a 2001 gsr. I have s2s2 cams, s2 intake manifold, itr pistons, smsp header and other bolt ons tuned on neptune with a p28 obd1 ecu. I have had the car running fine for the past 3 months. I had to take emissions so i had to plug back in my obd2 ecu. After taking emmisions with my obd2 ecu in i threw p0420 code and my idle went crazy fluctuating from 1200 to 2000 when i was at a stop and my car started running really rich. I switched back to obd1 and cleaned my iacv. Cleaning the iacv helped out the idle a little bit but it still runs rich and the idle flucuates when you start is and the idle sits a little higher now. Anybody have any ideas on how to fix this or what to do? Thanks
Old Sep 14, 2007 | 07:49 AM
Relic1's Avatar
p0420 was due to you not running a cat or secondary O2 (or the O2 is bad)
but it wouldn't change the way the car runs.
which OBD2 ECU did you use? (it matters a lot)
Old Sep 14, 2007 | 09:03 AM
tpdc2's Avatar
Default Re: (Relic1)
my stock gsr one p72. Oh and i was running a cat at the time. i am currently running a test pipe.
Old Sep 14, 2007 | 10:58 AM
b18c1ej8's Avatar
Default Re: (tpdc2)
obd2 will expletive u with the o2 sensors
Old Sep 14, 2007 | 11:00 AM
tpdc2's Avatar
Default Re: (b18c1ej8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1ej8 &raquo;</TD></TR><TR><TD CLASS="quote">obd2 will expletive u with the o2 sensors</TD></TR></TABLE>
i know. is there a fix for my situation?
Old Sep 14, 2007 | 12:12 PM
Relic1's Avatar
this in no way is meant to go around the emissions laws here in IL.
have an O2 simulator soldered inside the ECU and disconnect the secondary O2 signal wires. But run the secondary O2 in the test pipe to keep the heater portion working.
Old Sep 14, 2007 | 01:02 PM
tpdc2's Avatar
the code is really not the problem now for me its the idle surging and running rich unless this will help. btw i think relic1 i think you worked on my buddies red ek a year ago you wired his obd2 ecu up so he can pass emissions. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">this in no way is meant to go around the emissions laws here in IL.
have an O2 simulator soldered inside the ECU and disconnect the secondary O2 signal wires. But run the secondary O2 in the test pipe to keep the heater portion working.</TD></TR></TABLE>
where can i get a simulator and how hard is this?
Old Sep 14, 2007 | 01:45 PM
Relic1's Avatar
Default Re: (tpdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tpdc2 &raquo;</TD></TR><TR><TD CLASS="quote">the code is really not the problem now for me its the idle surging and running rich unless this will help. btw i think relic1 i think you worked on my buddies red ek a year ago you wired his obd2 ecu up so he can pass emissions.
where can i get a simulator and how hard is this?</TD></TR></TABLE>
it's very possible that I did, I've helped a few people in the area with emissions codes.
if you can solder it's really easy.
http://www.mkiv.com/techarticl...lator
I've made several of these and not a one had a problem.
the secondary O2 is emissions only, something else is causing it to run rich and idle funky.
Old Sep 14, 2007 | 02:29 PM
tpdc2's Avatar
thanks relic1
something else is causing it to run rich and idle funky.</TD></TR></TABLE>
Anybody know how to fix this problem? or y it occured.
hondamyheart
Nov 7, 2016 11:19 AM
tpdc2
Sep 13, 2007 05:56 PM
stratedrm
Jun 28, 2007 02:12 PM
7808
Apr 16, 2007 09:36 PM
StinkyTofu
Apr 6, 2003 09:31 AM
