Name that ticking noise!
k i got stock valve train at the moment upgrading real soon within 2 weeks taking it real easy on the car when i drive it
setup is
b18c1 with ctr pistons
b16 head stock valvetrain getting RM springs and retainers
Skunk2 Stage 2 cams
valves adjusted to .006 on intake and .008 on exhaust
on the cam sheet it says to put the valve lash of .007 on the intake but the feeler gauge i bought from schucks only went by 2s so i had to make do
would that be the cause of the ticking noise?
heres the link
http://www.youtube.com/watch?v=8Q6c3hl5FXM
setup is
Skunk2 Stage 2 cams
heres the link
Why are you running S2S2 cams on stock valve train?
It's probably the LMA's you're hearing. I had to replace mine with ITR, and it helped with the noise a little. I also had really worn valve guides, and once those were replaced it cut the noise in half.
Good luck.
Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludedriva »</TD></TR><TR><TD CLASS="quote">k i got stock valve train at the moment upgrading real soon within 2 weeks taking it real easy on the car when i drive it
setup is
Skunk2 Stage 2 cams
heres the link
http://www.youtube.com/watch?v=8Q6c3hl5FXM</TD></TR></TABLE>
what size injectors r u runnin???
mine has a similar noise and my boys and i realized it was my 400cc injectors...
setup is
Skunk2 Stage 2 cams
heres the link
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93EGB18C1 »</TD></TR><TR><TD CLASS="quote">Why are you running S2S2 cams on stock valve train?
Good luck.
valvetrain is being installed next week taking it real easy on the car til then
Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Master of the Universe »</TD></TR><TR><TD CLASS="quote">DO NOT HIT VTEC!</TD></TR></TABLE>
Already warned in another thread.
longuyen88
12
Jun 14, 2006 04:48 PM
