Help!!! b18a into 93 civic ex
i have a 93 civic ex coupe and bought a 90 integra with a fully rebuilt b18a in it...cable tranny....the car is all there but i need to know anything and everything i need to buy before swapping the b series into my coupe(the minimum parts)....im buying a hydro ls tranny also...and im gettin an obd1 distributor this week...what else do i need to swap it in.....
please help! iv searched high and low, thanx
Modified by 19ekcoupe96 at 10:17 PM 9/15/2007
examples...what stock parts can i use from the integra, what stock parts can i use from the civic....i need to know everything!! thanx again
You should be able to run the car with your ex engine harness. Take out your sohc. assemble the B18A and the GSR tranny. Will need hydro clutch and flywheel. Then throw that bitch in there. Will need a B series throttle cable too.
EDIT: axles , B series shift linkage
i was told i can use the integra axles? and also..the new hydro tranny comes with shift linkage...but are the shift linkages even different between cable and hydro transmissions?
Well since you got the axles and shift linkage thats good. how about ECU? and no the cable clutch n flywheel will not work in the hydro. Two different types of systems.
sick man...i appreciate all the help...one more question...about the wiring...what will i do about that? i already got the distributor and ecu figured out...but im talkin bout the engine wiring...thanx again
What doood said sounds right. But it wouldnt hurt to install a new flywheel with that hydro clutch disc.
Well as for wiring. Since both engines are obdI most plugs should hookup. You wont need the vtec plugs though, so just leave those unplugged when wiring the engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayKayNidas »</TD></TR><TR><TD CLASS="quote">What doood said sounds right. But it wouldnt hurt to install a new flywheel with that hydro clutch disc.
Well as for wiring. Since both engines are obdI most plugs should hookup. You wont need the vtec plugs though, so just leave those unplugged when wiring the engine.</TD></TR></TABLE>
so nowww i understand the whole clutch thing.....well the integra motor is obd0, and the civic is obd1, so thats where im still stumped...
swap is in, used obd 1 ecu, distributor and hydro tranny....started right up, the fuel pump only comes on sometimes....when i put the key in on position...and sometimes the fuel cuts out when im driving....does anyone kno what this could be? either main relay or my fuel pump??
civicblowsbyu
Jul 9, 2005 06:48 AM
turbotime
Mar 15, 2004 08:55 PM
