Inner axle poping?
Old Sep 13, 2007 | 07:18 PM
b16a1eg6's Avatar
Default Inner axle poping?
Recently a weird noise has been coming from my civic. When I take off from a stop or apply the brakes I hear a pop from the engine bay. I found out that if I am stopped with the e-brake on and rock the car back and forth(1st then reverse) it makes the same noise. It doesnt make the noise wheb I turn to full lock and when I am already moving. I took a look at it today and all the motor mounts are good(HAsport b-series). Also non the the suspension compenents are loose. Does this sound like the inner axles are bad. BTW they are 2-3 year old Raxles.
Also does this look bad?
before
after
I havent changed my trans fluid since spring. It does have a litlle third gear grind.
Old Sep 13, 2007 | 07:23 PM
Crx Jimmy's Avatar
Default Re: Inner axle poping? (b16a1eg6)
no that magnet isnt that bad. If it had that much crap on it after 3000 miles yes it would be bad, but that is ok, mine looks like that too
Old Sep 13, 2007 | 07:30 PM
b16a1eg6's Avatar
Default Re: Inner axle poping? (Crx Jimmy)
Thats also with a full summer of auto-x.
Old Sep 14, 2007 | 04:04 AM
b16a1eg6's Avatar
I guess the only thing to do is to try new axles.
Old Sep 14, 2007 | 10:59 AM
barely4dr's Avatar
Bump
I have the same noise/problem. Hear it every morning pulling out of my driveway
Old Sep 14, 2007 | 02:24 PM
.coolguy's Avatar
Default Re: Inner axle poping? (barely4dr)
axl bolts tight?
Old Sep 14, 2007 | 05:00 PM
dubzz24's Avatar
Default Re: Inner axle poping? (.coolguy)
I've had bad inner joints before but have never heard them pop, it's more of a vibration but only under load when accelerating (not when decelerating).
What you're describing sounds like a problem I had on one of my EF's after replacing the pass side axle. I didn't tighten the 2 17mm bolts that connect the radius arm rod to the LCA quite tight enough and after a few hundred miles they backed out enough to make some play and start clunking. Even if all your suspension stuff looks / feels tight, throw a ratchet on there and make sure.
Old Sep 15, 2007 | 12:53 PM
b16a1eg6's Avatar
Default Re: Inner axle poping? (dubzz24)
I thinks thoughs are the only bolts I did not check.
Old Sep 22, 2007 | 08:05 AM
b16a1eg6's Avatar
Ok I checked the radius rod bolts and they were tight. But I got to looking at the back of the engine and it turns out the rear tranny bracket only had two bolt in it and one was loose. So I put an other bolt in it and torqued it down. No more popping sound
Old Sep 22, 2007 | 08:46 AM
cr-x-91's Avatar
for that 3rd gear grind....use penzoils synchro mesh...it will bring a smile to ur face.
Apple395
May 28, 2015 10:09 AM
mark2583
Dec 7, 2008 06:12 AM
lopezchris21
14
Aug 10, 2008 06:57 PM
BLK99VTECR
Nov 10, 2003 01:16 PM
Steveo92'vx
Sep 1, 2003 09:38 PM
