is putting a gauge on the turbo and bad idea
Old Sep 13, 2007 | 07:06 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
Default is putting a gauge on the turbo and bad idea
i had a old b&m fuel gauge lying around so i decided to put it on my turbo feed line w/ a tee. will it get to hot and melt and has anyone else done this. just trying to see if its a good or bad idea and heres a pic so u can see what i did
Old Sep 13, 2007 | 07:48 PM
.RTErnie's Avatar
Default Re: is putting a gauge on the turbo and bad idea (street dreams)
Im sure there are temperature sensitive components within the gauge... I would move it.
Old Sep 13, 2007 | 07:53 PM
MidShipCivic's Avatar
What are you measuring oil pressure?
Old Sep 13, 2007 | 08:06 PM
Muckman's Avatar
Moderator in Chief
Default Re: (MidShipCivic)
... well he certainly isnt measuring fuel pressure to his turbo.
Old Sep 13, 2007 | 08:55 PM
Finest's Avatar
Default Re: (Muckman)
Any reason why you can't tee it further away?
Old Sep 13, 2007 | 10:26 PM
DrivinVtec's Avatar
WOW!!
Man. just order me a autometer 2" oil pressure gauge:
http://cgi.ebay.com/ebaymotors...h=014
an i was going to do the same thing. Glad i looked at this thread. Im going to use a small oil line i have laying around an mout it further off away from the turbo. Thank for post this
Old Sep 13, 2007 | 10:40 PM
Tony the Tiger's Avatar
Looks like a good idea... Did that for my other car too
Old Sep 13, 2007 | 10:43 PM
DrivinVtec's Avatar
is that that the gauge right at the turbo?
Old Sep 14, 2007 | 04:11 AM
Default Re: (DrivinVtec)
i have a oil pressure gauge in the car too for the motor, i just wanted to see what the oil pressure for the turbo was
Old Sep 14, 2007 | 09:52 AM
dpetro1's Avatar
Default Re: (street dreams)
it might be good for a periodic check to look for under or over oiling but as others have said maybe not a permanent location.
Old Sep 14, 2007 | 09:55 AM
*Boostwerks*'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">... well he certainly isnt measuring fuel pressure to his turbo.</TD></TR></TABLE>
lol. Hilarious.
Old Sep 14, 2007 | 11:43 AM
tegman23's Avatar
i had a problem with a blown turbo,my oil line got somthing inside it stoped oil to the turbo and it blew....so i put a t on the turbo ran the same line that i ran to supple the oil into the car and put the gauge in there..sorry dont have a pic try to put one up though
Old Sep 14, 2007 | 11:59 AM
BTW, I just had to mention...
The most common location for the sender of an aftermarket electric oil pressure gauge is almost always the feed line for the turbo. If you have this gauge already, but are still thinking about putting a gauge at the turbo...you should question your thought process.
After all, a gauge isn't going to do much good unless you can actually see it.
Old Sep 14, 2007 | 12:01 PM
integraRS-T's Avatar
i dont think its a bad idea as long as somthing dosent melt inside of the gauge,knowing if ur turbo is getting oil incase somthing claugs the oil feed it would be good to know
Old Sep 14, 2007 | 12:02 PM
DrivinVtec's Avatar
i can see what your saying i guess. it kinda like a fuel pressure gauge. why have one if u cant see it. same difference.
Old Sep 14, 2007 | 12:06 PM
powerdbygarrett's Avatar
^what if you got two free mechanical gauges and didnt wana run them to the cabin. and already had those gauges in the cabin. put them under the hood for looks?
Old Sep 14, 2007 | 12:12 PM
Sell them, and get an in-cabin electric gauge. honestly...having an oil pressure gauge on the turbo will not save it...unless you happen to be watching the gauge right as the line gets clogged. Good luck with that
Old Sep 14, 2007 | 12:14 PM
DrivinVtec's Avatar
i have an auto meter gauge in the cabin also. it just a good refrance jut in case something goes wrong an u have smoke coming out the back or soemthing
Lithel
Oct 2, 2008 05:04 PM
jarven093
Apr 26, 2007 04:47 PM
95LStizzy
Mar 12, 2006 12:35 PM
SRd240sx
Nov 22, 2004 06:43 PM
Pengo
Jun 26, 2002 08:24 AM
