car truble
Old Sep 13, 2007 | 03:47 PM
oluc12's Avatar
TRIAL USER
Default car truble
my car starts when i turn it on but then it just dies out and after a few minutes i try again and it works normally. Wat the heck is wrong with it?
Old Sep 13, 2007 | 04:04 PM
crxricer66's Avatar
Default Re: car truble (oluc12)
is the fuel pump priming?? if it primes and then stops then prolly main realy. reach under the panel and flick it a littl bit and see if it helps.
Old Sep 13, 2007 | 04:05 PM
97Ej6mike's Avatar
Could be a number of things.
Common issues would be a clogged fuel system of some sort, and/or too low of an idle. Whats your idle at before it dies? how often do you do tune ups? ( plugs, wires, oil, cap, rotor, ect) Have you tried putting some injector cleaner thru your system?
Old Sep 13, 2007 | 04:12 PM
pac-west 388's Avatar
when the car dies u need to check to see what u lost i.e. either spark or fuel. If it is spark i would look torwards a faulty coil or igniter. If u lost fuel pressure i would ck the main relay first. Good luck
eg6noise
Mar 9, 2019 11:19 AM
Connorjaymes
10
May 12, 2018 07:28 PM
waynecoSI
Oct 2, 2008 04:04 AM
innes887
10
Jan 14, 2008 06:11 PM
bulldogg9279
Apr 15, 2007 11:30 AM
